Home > Technical (L322) > Hard brake pedal |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8523 |
Done a bit of googling while waiting to have my hair cut.....
16th Feb 2019 9:56am |
chefkenmore Member Since: 11 Jan 2015 Location: Fearnan perthshire Posts: 749 |
Mine does that, now and again!
16th Feb 2019 10:02am |
LR046916
16th Feb 2019 10:23am |
Had a quick look and the pipe is an easy swap, there is an NRV in the end of it on the servo end, but this is part of the pipe!! It may be possible to pull it off and put in a non standard valve but this will be a bit of a bodge...... on the brakes.....which is not a brill idea... There is nothing that can't be fixed with a hammer😜😜
16th Feb 2019 11:15am |
Pawl Member Since: 07 Nov 2017 Location: West Midlands Posts: 693 |
Yes, there is a Non Return Valve in the servo or possibly, somewhere along the vac pipe.
16th Feb 2019 11:21am |
It’s one of those LR pipes which is shrunk onto the fitting, going to try and get it off the old one when it’s out and if I can find a replacement then I will do that, I have ordered a replacement pipe, which I will return if I can swap out the valve but if not will put the new pipe in.
16th Feb 2019 3:49pm |
Have fitted the new vac pipe today, was about a 15min Job.
21st Feb 2019 9:20pm |
steveball Member Since: 09 Jun 2011 Location: Corsham, UK Posts: 208 |
Watching with interest as I have a similar problem.
21st Feb 2019 10:16pm |
Got a discount from local MD so was £72. There is nothing that can't be fixed with a hammer😜😜
22nd Feb 2019 12:20am |
NMJ - wondering whether replacing the vacuum hose on yours solved the occasional hard brake pedal problem you had/ If so, I am minded to try the replacement to attempt solving a similar problem on mine.
1st Jun 2019 9:14pm |
unfortunately no.
4th Jun 2019 6:48pm |
number76 Member Since: 30 Oct 2013 Location: UK Posts: 47 |
Hi NMJ.
15th Feb 2024 9:51am |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3236 |
Mine does it as well. I replaced the non return valve but it didn't fix it even though the old valve had a leak when I tested it on the bench. In hindsight I should have tested the new valve before fitting it. I just bough a generic part and joined it to the existing hose as even if you disconnect the hose after shutdown it should still hold vac. I suspect the servo is leaking internaly but I just live with it as it's only a slow leak and does not effect the brake pedal assistance when the engine is running and it holds vac during use in the day. 2012 TDV8 Vogue (L322) |
15th Feb 2024 10:10am |
AJGalaxy2012 Member Since: 11 Jun 2018 Location: Gainsborough Posts: 1464 |
Diaphragm in the servo? BMW i3 Electric Car 2012 Full Fat RR 4.4 TDV8 (now gone) 2006 VW Touareg 3.0 TDi V6 |
15th Feb 2024 10:58am |
