Home > Maintenance & Mods (L322) > Cost of Maintenance? - Opinions/Experience please?
DrRob
4 wheel alignment. £55 at my local place and they have an IID for setting Tight Tolerance Mode. Don't be fooled by the "open a door" method! You need a place that can lock it into Tight Tolerance Mode.
If you have your own IID then even better - DIY! Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #505573 18th Feb 2019 3:39pm
DrRob
Also: get a quote for parts from Advanced Factors aswell. Site sponsor etc.
https://www.advancedfactors.co.uk/brake-parts-51-c.asp Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #505576 18th Feb 2019 3:45pm
Paul thornton
The boot seals are really expensive from LR, I know, I priced one up. Luckily for me I found a mint one in my local LR breakers. I say lucky because it wasn't actually the cause of my boot leak!
Post #505606 18th Feb 2019 9:19pm
Bazzer79
United Kingdom 2007 Range Rover Supercharged 4.2 SC V8 Barolo Black
Dr Rob - thanks for highlighting the need for tight tolerance mode, was going to get the tyre shop to do the alignment, think I'll get my indy to do it instead!
Post #505633 19th Feb 2019 9:54am
Bazzer79
For axle stands do I need a min/max height requirement - presumably a reasonable amount of lift/height is needed to get the wheels off the ground?
Post #505663 19th Feb 2019 3:18pm
