Home > Maintenance & Mods (L322) > Where to buy refurb Turbos from
toddy2
United Kingdom 2009 Range Rover Vogue SE Td6 Java Black
Hi All,
Previous thread I raised both turbos have blown and in need of replacement.
I have decided to use a local guy to do the work, but will buy the refurbished turbos - any suggestions on where to buy these from? TD6 V8 FFRR
Anything else I should consider doing when the works are being done?
Many thanks,
Post #505101 14th Feb 2019 1:06pm
gettingold
Dorset way I have previously used Turbo dynamics in Christchurch. Good service and never had an issue.
Steve.
Post #505107 14th Feb 2019 1:47pm
essex boy
London Turbos Romford Essex might be worth a look
Ask for mindus say Martin electrician put you on to him he might do a deal if all is good for you
Post #505135 14th Feb 2019 6:02pm
GDM
United Kingdom 2006 Range Rover Vogue Td6 Zambezi Silver
I found Essex turbos to be very good when our 520d BMW needed one. I had a bad experience with Universal Turbos for the Td6. When it was first fitted the turbo seals were faulty and it had to be replaced. Cost me double the garage labour charges and I never did get an apology from them
Post #505178 14th Feb 2019 11:45pm
paulbrown22
United Kingdom 2011 Range Rover Supercharged 5.0 SC V8 Stornoway Grey
Universal Turbo's in Fordingbridge rebuilt my Yanmar/IHI boat turbo a number of years ago now, and that's been perfect ever since. Turbo Dynamics in Christchurch didn't want to do the job.
My Defender TD5's turbo was rebuilt by Turbo Technics (I think, but was someone with a regular advert in the back of LRO in any case!), and that was perfect when I sold the vehicle last year when buying my L322.
Post #505412 16th Feb 2019 9:28pm
which model do you have? TD6, TDV6, TDV8? Question
I'm assuming 3.6 tdv8.
before you go off and purchase 2 new turbos, make sure that you have someone check out the rest of the engine to make sure that none of the internals from the impellers have ended up inside Thumbs Up There is nothing that can't be fixed with a hammer😜😜
Post #505413 16th Feb 2019 9:37pm
AJGalaxy2012
Ive used Midland Turbos loads of times, brilliant service, know their stuff and very quick turnaround. BMW i3 Electric Car
2006 VW Touareg 3.0 TDi V6
Post #505434 17th Feb 2019 8:33am
