![]() | Home > Technical (L322) > L322 4.4 TDV8 faulty oil level sensor |
edward19 Member Since: 11 Feb 2019 Location: South Coast Posts: 55 ![]() ![]() ![]() |
Hi Richard
Hi All
rjff Member Since: 28 Oct 2017 Location: Cambridgeshire Posts: 1196 ![]() ![]() ![]() |
Well done |
SFM Member Since: 19 Feb 2012 Location: dordogne Posts: 258 ![]() ![]() ![]() |
Can someone tell me where the oil drain pipe is, that was mentioned please?
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3826 ![]() ![]() ![]() |
Slight confession in that the f type connector has started leaking. What a pain, so I've bitten the bullet and ordered a replacement hose. However does anyone know the best process for draining the coolant on the 4.4 tdv8? Any tips would be great. Also I got a rather weird ticking noise from the Top left hand side of the engine (off side) for a bit when cold. It went away and might be a screw rattling that I lost when putting the new idler pulley in!!!
Xpand1t Member Since: 02 Jun 2022 Location: kent Posts: 6 ![]() ![]() ![]() |
Hi did you ever replace the oil sensor or find the reason why you were getting this fault message,
