Home > Technical (L322) > Key fob battery
saj2421
United Kingdom 2006 Range Rover SE Td6 Java Black
Key fob battery
Hi folks
My 2011 key fob is showing smart key battery low
What is the battery code so I can pick one up and swap it
Thanks Thumbs Up
Post #504470 8th Feb 2019 2:31pm
RRV78
England 2003 Range Rover Vogue 4.4 V8 Java Black
My 2010 is cr2032 Current: 16 my2016 Range Rover l405 4.4 sdv8 Aruba gold & 11 MY2011 RANGE ROVER L322 4.4 TDV8 ZERMATT SILVER
Previous
59 MY2010 Range Rover Vogue L322 3.6 TDV8 Zermatt Silver
53 Range Rover Vogue L322 4.4 V8 Java Black
98 P38 Range Rover 2.5 DSE Champagne Gold
Post #504471 8th Feb 2019 2:33pm
Baltic Blue
Make sure you get a Duracell type CR2032.
Max cell definitely don’t work.
Post #504472 8th Feb 2019 2:41pm
saj2421
Thanks guys
Btw is it a simple case of open fob put in new battery and away you go?
Post #504538 8th Feb 2019 10:40pm
GGDR
 Cheers, Greg
Post #504540 8th Feb 2019 11:28pm
Bradders
United Kingdom 2012 Range Rover Westminster TDV8 Zermatt Silver
Just changed batteries in both key fobs with Duracells and the old ones were Energizers. They had been working fine since I bought the car last summer but were clearly running out of juice.
Took about 2 mins to do both Very Happy Current: FF Westminster money pit
Gone:
RRS 4.2 SC
RRS 3.6 TDV8
FL2 TD4
Post #513587 29th Apr 2019 6:04pm
DrRob
Is it definitely + ve upwards? One I took out for the other way round.....off to find some Duracells Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #538608 27th Dec 2019 5:10pm
yep, plus upwards....dont forget to take the sticker off as well...how do i know , well Embarassed ... - .- -.
Post #538610 27th Dec 2019 5:13pm
DrRob
Thanks. So +ve upwards when the buttons are on top like above manual picture? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #538611 27th Dec 2019 5:26pm
DrRob
Useful video
-ve upwards NOT +ve.
Also a top tip at end if dash still shows smart key battery low Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #538817 29th Dec 2019 2:31pm
ooohh......is that with the key upwards or downwards......im sure mine was plus up on the circuit board... ... - .- -.
Post #538824 29th Dec 2019 3:38pm
DrRob
Key upwards. Clearly shown on video Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #538825 29th Dec 2019 3:47pm
that would be plus up on the board then? ... - .- -.
Post #538827 29th Dec 2019 3:52pm
DrRob
No idea I'm afraid. Defo -ve upwards with fob buttons on top side if that makes sense. Video shows it clearly Bow down Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #538829 29th Dec 2019 4:07pm
ok thanks Rob...its a 50/50 chance in getting it right... Laughing ... - .- -.
Post #538833 29th Dec 2019 4:50pm
