Home > Wheels & Tyres > changed wheels and tyres |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3237 |
Nice. Style 502. John
7th Feb 2019 5:09pm |
DaveK Member Since: 18 Oct 2013 Location: StHelens Posts: 790 |
I have these wheels...an actual pleasure to clean !! |
17th Feb 2019 11:12am |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3776 |
+1...
17th Feb 2019 11:49am |
Springer Member Since: 15 Nov 2017 Location: Merseyside Posts: 104 |
Me too look great |
17th Feb 2019 12:15pm |
Cavalier Member Since: 04 Sep 2015 Location: Bletchley Posts: 189 |
Just as a side note warning, I changed my wheels in my garage, door closed garage heater on, suspension in off road, jacked up using the correct jacking points with my new sprinter Jack, all went lovely till I pressed the garage remote for the up and over door. !!! , , arsoles the garage door opened, hitting and breaking the high brake light, bounced along the car roof, many dents and deep scratches would you believe it in my panic to stop the door it when the into reverse and did the same damage again closing itself
17th Feb 2019 2:41pm |
Swipe Member Since: 31 Aug 2018 Location: Rustington, West Sussex Posts: 101 |
Got these wheels on my 2004 Td6 I think it gives the car a classier look, just put 4 brand new Michelin latitude tyres on a change from the Pirelli’s Scorpions.
21st Feb 2019 6:04am |
Dolphinboy Member Since: 07 Dec 2009 Location: Bristol Posts: 3166 |
@cav,
21st Feb 2019 7:41am |
Hi DB
21st Feb 2019 6:41pm |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4306 |
Does it ride nicer on 55 compared to 50s? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
3rd Mar 2019 12:06pm |
I would say definatly |
3rd Mar 2019 1:25pm |
Red Merle Member Since: 19 Sep 2016 Location: Cornwall Posts: 2158 |
I’ve never thought about this before, but are the standard fitment bolts stainless steel? |
3rd Mar 2019 2:07pm |
I'm not sure they can be as they rust under the cosmetic cover causing the covers to swell. |
3rd Mar 2019 3:12pm |
If they are were steel originally, please take care. Stainless bolts are unlikely to have the same strength as the original bolts and might fail. I use stainless bolts where ever possible, but never on a size for size basis with steel, where the loading is high and where they are structurally critical. Please could a metallurgist step forward, for a qualified opinion, at this point? |
3rd Mar 2019 3:40pm |
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1385 |
Dealer advised me against stainless nuts when mine (on 2012 WM) had to be replaced due to swelling, concern was not strength but corrosive reaction between alloy of wheel and stainless. This seemed counter-intuitive to me, but some research on line showed US construction industry support for it. As the standard nuts were replaced under warranty I left at at that.
4th Mar 2019 1:06pm |
