Home > Technical (L322) > Rear left height sensor problem
Andyv8
United Kingdom 2010 Range Rover Autobiography 5.0 SC V8 Java Black
I’ve got adaptive dynamics fault up in my my10 5.0 s/c. After looking on the IID tool it comes up with ADCM - Active Damping. C1A06-14 (AF) Rear left height sensor - general electrical failure - circuit short to ground or open.
I’ve searched the forums and found a few posts that stated that it’s normally either a sensor or the wires where they go over the tank. I checked the wires today and they all seem in good condition but I’m getting resistance between black/yellow and black/red wires. Black/yellow also has a solid connection to earth somewhere. I cut the wires inside the car above where they go under the car and I’m still getting the same results on the wires. If I check the right hand sensor wires I get no resistance between any wires nor are any ground to earth so I presume the left sensor should read the same. So should the left hand sensor wires have any connection to earth or have i got a problem between the ecu and the boot?
Post #503848 3rd Feb 2019 6:35pm
jeff88
France 2011 Range Rover Vogue TDV8 Ipanema Sand
hello,
the right sensor is not the same in the left.
Left side, front and
back
WHITE
Right side, front and
back
BLACK
Output voltage
Left and right back: the tension decreases in compression and
increases in rebound
Front left and right: the tension increases in
compression and decreases in rebound
one side give a signal used for the principal beam
jf
Post #503853 3rd Feb 2019 7:29pm
