Home > Technical (L322) > 2012 TDV8 Autobiography, new owner needs advise
Kjon
Hi all, just bought a 2012 TDV8 Autobiography, & I’m very pleased with it.
The car drives without fault, everything appears to be working as it should with one exception. The front central interior light works fine but the map lights & vanity mirror lights both front & rear do nothing. Am I missing something obvious or should I start checking fuses/wiring?
Also, given the car has covered 84,000 miles do you think I should consider changing the gearbox oil?
Post #503735 2nd Feb 2019 8:49pm
GGDR
Yes for fuses.
Yes for gearbox
Also transfer case oil and 2 x diffs.
. Cheers, Greg
Post #503742 2nd Feb 2019 9:07pm
Spooky
United Kingdom 2014 Range Rover Autobiography 5.0 SC V8 Corris Grey
Try fuse 57 (10 Amp) in the fusebox behind the glovebox. Regards,
Mick
'Bertha' - 2014 SDV8 Autobigraphy
'Vincent' - 2010 TdV8 Vogue SE
- 'Molly' - 2005 HSE Auto
'Dixie' - 2000 D2 Td5 ES
Post #503760 2nd Feb 2019 10:35pm
