![]() | Home > Maintenance & Mods (L322) > new struts camber adjustment |
Blue Hornet Member Since: 25 Sep 2018 Location: Sawtell Posts: 17 ![]() ![]() ![]() |
I have recently replaced my front air struts and I am finding it difficult to get the camber adjustment done when I go to get an alignment. Originally I went to the dealer and that was another story.
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2641 ![]() ![]() |
I'll be suggesting the nuts be sufficiently loosened to allow them to be tapped sideways as required. |
dexion7 Member Since: 06 Jun 2013 Location: Tynemouth Posts: 291 ![]() ![]() |
considering the bolts/nuts that hold the strut to the hub, maybe there is suffiicient clearence of the bolts in the strut to slacken those off and adjust camber that way? |
Thanks guys. \ OK thats sounds easy any idea about snapping off the little plastic piece in the attached photo as suggested in the manual? |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6418 ![]() ![]() |
For all vehicles (up to 2010), the position of the studs should be marked before removal to ensure correct alignment on replacement or fitting of new strut, and thus the camber is retained. I am with the others, loosen three studs and tap with a hammer until camber is correct. You shouldn't "have to" snap off the plastic cone unless things are really out of kilter.... .
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8747 ![]() ![]() ![]() |
Did the alignment place settle the car properly before putting it on the ramp
MY10-12 specs are -0 20 +/- 0 45 with max cross-camber 0 45 so both are within these specs but one positive and the other negative and the positive on the gutter side wouldn't make me very happy. |
and when fitting strut everything should be tightened up with the "wheel on the ground", i.e. weight on suspension. .
Just cannot get enough camber by moving the top of the air strut to required settings even with LRT 57-045 |
Bigvinno70 Member Since: 02 Oct 2024 Location: Dublin Posts: 2 ![]() ![]() ![]() |
Just into the RR world and had LCArms replaced.. alignment place said everything was perfect but didn't know how to adjust front CAMBER..
JamesDarby Member Since: 29 Sep 2021 Location: Rugby Posts: 25 ![]() ![]() ![]() |
Hi,
The plastic point is purely for ease of fitting the strut and should be removed if more adjustment is required. |
Scouse Exile Member Since: 09 Dec 2022 Location: East Midlands Posts: 405 ![]() ![]() ![]() |
This is the way to go, I luckily had the foresight to mark the position of each of the three studs (after much research!) and it help enormously with a post fitment alinement. You’d be surprised how much movement there is at the top of the strut even with the plastic retaining stud. Jon |
