Home > Technical (L405) > Battery Charging
Gold Ranger
United Kingdom 2010 Range Rover Vogue TDV8 Santorini Black
thanks for that alistair - didnt think to look there
have downloaded the pdf and printing it off now
Post #593550 7th May 2021 9:10pm
BigTrev
Australia 2017 Range Rover Vogue SE SDV8 Fuji White
I have a 2017 SE TDV8 and run a Thinkware front and rear camera. If I didn’t use the car for a few days I was getting the “low battery - start engine “ warning. In addition the camera shutdown after a few minutes . I had made enquiries to see about getting a dedicated battery for the camera in order to have total recording in parking mode.
At a recent dealer service they picked up the warning and told me they did a software upgrade to address it. The problem is now fixed and the camera records permanently when parked (motion activated) and no more warning pops up.
I told them if the upgrade made the stop start/ work again I would bring it back for a software reversal. I have now had stop/start operate intermittently a couple of times but not enough to concern me.
Might be worth talking to a dealer or good Independant to see if they can address this issue. I am very happy with the change. disco 1997 SE7 Tdi [gone]
Disco 2003 Td5 [gone]
Disco 3 2008 HSE [gone]
Disco 4 2011 HSE Tdv6 [gone]
Disco 4 2015 SDV6 HSE [going]
Vogue 2017 SDV8 SE [my dream car ~ staying]
Post #594314 15th May 2021 9:51am
knwatkins
Trev, do you know specifically what software was updated to fix please?
I get the battery low message too after a few days. Kev
2014 L405 RR Vogue SE 4.4 SDV8 in Corris Grey
2010 L320 RRS HSE 3.0 TDV6 in Stornoway Grey
Post #594367 16th May 2021 8:03am
BigTrev
Kev
Taken from the service report as follows:
Low battery warning on – when ignition is turned off.
Inspected and confirmed customer concern.
Carried out DTC scan and found code PB141 2–96 logged
Carried out gateway relay functional checked via pathfinder
Carried out update to gateway module software.
Checked after update. All okay
Hopefully that helps you find a solution.
Cheers
Trev disco 1997 SE7 Tdi [gone]
Post #594507 17th May 2021 1:56pm
Landphil
A question about batteries.
My car, an MY15, does not have Intelligent Stop Start. The book has a section on it but I don’t seem to have the button and the car has never done it.
So why do I have two batteries? I know that the main battery does all the starting, but I thought the second battery was there to maintain a minimum voltage for other circuits while all this stop start malarkey was going on.
Post #603263 9th Aug 2021 10:42am
normally the second battery located in the right rear cubby is for the stop/start but it can also be for helping cold starting .. ... - .- -.
Post #603264 9th Aug 2021 11:07am
horse86
United States 2014 Range Rover Autobiography 5.0 SC V8 Causeway Grey
sub'd 2014 FF Autobiography 5.0 SC
2008 FFRR (sold)
2008 BMW M5
Post #603266 9th Aug 2021 11:51am
GrandadRob
England 2013 Range Rover Vogue SE SDV8 Luxor
Going second battery hunting today.
Can the main battery condition be tested through the jump terminals, to save hauling the spare wheel out.
Post #604913 27th Aug 2021 7:25am
