Home > Group Buys > Not quite a group buy -- but a group hire !!!
Bushy30
United Kingdom 2011 Range Rover Vogue SE TDV8 Galway Green
OK so that's got your attention!!
P040D-00 (2F) Exhaust gas recirculation temperature sensor A
Right after Greg successfully managed to change his sensor he noted you need a special tool -- now I intend to do the job at some point and he kindly made the tool available to purchase -- I've bought it !!
But as this is likely to be a one use tool I thought it might be useful to 'hire' it out to other forum members -- so here it is -- I'll likely charge you the cost of a new tool + postage to you as a deposit + a small donation to the site -- you send it back to me and I'll credit you the price of the tool minus the carriage to you.
That all make sense?
Cheers
Bushy Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
2004 FFRR Vogue 4.4 V8 with LPG
1997 P38 4.0 SE with LPG
1997 P38 4.6 Vogue with LPG
Post #502786 25th Jan 2019 8:09pm
Might want to share which tool it is and which sensor you are referring to sir... Whistle
Post #502798 25th Jan 2019 10:20pm
Baltic Blue
Greg will confirm, but you need to stress to whoever uses the tool it MUST NOT be used to remove the old sensor, but only to fit the replacement new sensor., otherwise it will spread and become useless.
Post #502801 25th Jan 2019 10:24pm
Bushy30
Thanks chaps, edited, and yes more info from Greg soon about all the wrinkles, most are covered in his write up, which he has promised to condense for the wiki Smile Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
Post #502805 25th Jan 2019 10:41pm
