Home > General > Sunroof
ben2012
2005 Range Rover Vogue Td6 Buckingham Blue
Sunroof
I have a 2005 ffrr and have noticed that on some occasions the sunroof seems to magically open it's self not fully though it just goes down at the back of the glass as if it's going to slide back but then stops! Anybody got any ideas about this? I know u can open the windows and sunroof from the key but usually the windows open first so don't think it can be that. Thanks ben
Post #53030 5th Mar 2011 1:02pm
Stocky
United Kingdom 2019 Range Rover Autobiography 2.0 PHEV Fuji White
Might need recalibration of the motors. A friend had similar problem on his D3. Found the answer on the similar D3 site. It may be in the manual though. It was only a couple of button pushes/holds in the end.
Post #53031 5th Mar 2011 1:07pm
nick h
2005 Range Rover Vogue 4.4 V8 Tonga Green
my dad had a 2004/5 BMW 528i SE and it had the same problem!
so assuming the RR has the same electrics its no surprise!
i've sadly no suggestions but Dan will probably say its damp related and run the aircon all the time Laughing
and he may well be correct
Post #53032 5th Mar 2011 1:08pm
Stocky
The D3 recallibration was :
Turn on ignition position II
Hold in sunroof forward button for 20 seconds
Sunroof will then cycle through a full open and close (not sure if you need to keep button in or not whilst it does this bit)
Hope it works Smile
Post #53052 5th Mar 2011 4:29pm
elpeede
England 2003 Range Rover Vogue Td6 Zambezi Silver
nick h wrote:
......but Dan will probably say its damp related and run the aircon all the time Laughing
Only when its raining Laughing 2010 Disco XS TDV6, 2009 Freelander 2 GS
Previous Landrover products -1990 110 TDI CSW, 2003 TD6 Vogue - RRC TD Vogue, RRC v8 Fleetline, Disco ES V8 LPG, 101 Ambulance "Morph", 1964 SIIa Auto Powered by Jag 4.2 Lump - "Percy".
Post #53056 5th Mar 2011 4:51pm
Either that or has Fat Edna been in the car ........... Laughing ====================================
Post #53065 5th Mar 2011 6:17pm
M44K TS
"Slim Edna" Mick, get it right Laughing
Try disconnecting the switch and see if it still does it? Could be something simple like that. 2006 Mercedes CLS
1991 Retro-style Mini
But really finding it hard to fight the urge for a S/C...
Post #53068 5th Mar 2011 6:24pm
Embarassed Thumbs Up ====================================
Post #53069 5th Mar 2011 6:27pm
Vogue
Fat Edna sounds better though Shocked Laughing
Post #53104 5th Mar 2011 8:12pm
dan_uk_1984
No actually, because I'm not trying to be a smart arse (this time) I would suggest reading this post, where I detailed the "Sunroof Calibration Procedure" because actually, I do come onto this forum to try and help people. You may not have noticed, but damp IS one of the leading causes of electrical gremlins in RR's. I don't see you bitching when people suggest that electrical issues could be battery related which is the #1 cause of issues!
http://www.fullfatrr.com/forum/topic4017.html
Post #53109 5th Mar 2011 9:32pm
nick h
Dan
i'm sure that i among many others appreciate the assistance you give Smile
and i was in this instance quite genuine in suggesting that damp may be the issue!
and i've certainly taken on board your suggestion of running the air con full time
i'd never dream of 'bitching' at such a nice chap as your good self!
Post #53154 6th Mar 2011 12:31pm
M44K TS
Are you still talking about Dan? Laughing 2006 Mercedes CLS
Post #53158 6th Mar 2011 12:54pm
dan_uk_1984
Don't you have some accessories to go buy Rolling with laughter some tin door badges with your name on them I think!
Post #53183 6th Mar 2011 3:43pm
nick h wrote:
Dan
+1 Thumbs Up Thumbs Up
Bitching is for other forums Whistle ====================================
Post #53208 6th Mar 2011 6:20pm
comports
+ at least 6 from me. Bow down Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #53214 6th Mar 2011 7:09pm
