Home > Technical (L322) > Is there a knack to it?!
nickt68
2015 Range Rover Vogue SE SDV8 Santorini Black
Don’t know if anyone has experienced this but my 10my 3.6 TDV8 failed its mot last year for the following:-
Offside Front Drive shaft joint constant velocity boot split or insecure, no longer prevents the ingress of dirt (6.1.7 (g) (ii))
The garage (general not specialist) did the repair which a genuine LR ‘boot’. About a month later I had it serviced at a different garage and they rang to say the boot had split and needed replacing. Obviously I didn’t want to pay twice so took the car back to the original garage to fix under warranty.
Cutting a long story short, this has happened three times now. The last time a new LR clip was ordered to hold the boot. The original MOT garage have a very good reputation so I am wondering if there is a special tool or process involved for this job.
Or if the garage are in fact, cr*p?!! Wink
Post #502016 18th Jan 2019 5:24pm
stu1
Ummm. Perhaps your last question there. I had one of my front ones replaced back in June last year with a gen boot - no problems.
Post #502030 18th Jan 2019 6:59pm
nickt68
Thanks Stu, that what I was thinking but wanted to give them the benefit of doubt! They’re having it back on Tuesday to have a final attempt to fix it.
Just hoping that running it in this condition won’t have caused any further problems
Post #502135 19th Jan 2019 6:13pm
fisha
The proper clip should be clamped on with a special crimping tool designed for the clips (its a fairly standard type of crimp). Once its on, its really unusual / difficult for it to loosen / fail.
Whilst you can close it up in a bodge way without the tool, with the tool its a far better, cleaner grip formed by the clip running round the boot. You can in theory also re-use a clip ... but its much weaker and never really grips back together well.
There isn't really any special knack to the whole job as such:
Get the drive shaft out, take the boots off, split open one of the CV joints, slide new boots into place, put CV joint back together, fill boots with grease and fit the clips. refit the driveshaft.
There are some alternatives which in theory could save some time ... so a garage might try it ...
1) is to have a large cone shape tool to stretch the boot fully over the cv joint so that you dont have to split open one of the joints. Considering that the thin end of the boot is about 3cm diamter, and the cv joint is typically about 8 to 10cm diameter ... thats a lot of stretching of the rubber boot ... more that I would think is appropriate.
2) is to get one of the kits where the boot is pre-cut down its length, you wrap it around the joint, and then glue it back to close it up. Now unless you are able to keep the boot surfaces youre gluing clean, then how good will the join be, how good will it able to flex repeatedly etc etc ... i.e. I wouldnt trust it. V8 or else ...
Post #502586 23rd Jan 2019 10:13pm
Had one of mine replaced on the 3.6, the garage has one go at it and it wasn’t a problem again! There is nothing that can't be fixed with a hammer😜😜
Post #502589 23rd Jan 2019 10:35pm
nickt68
Thanks for your comments. They had it in on Tuesday to try again. Had a call Tuesday afternoon to say that they had caught the (suspension) airbag and punctured it whilst fitting the boot! Apologised profusely and said that they would replace it at their cost.
Picked up car yesterday evening and all was well in the one mile drive home! Fingers crossed it stays that way.......!
Post #502611 24th Jan 2019 10:20am
tony66
Scotland 2005 Range Rover HSE Td6 Tonga Green
issues
they dont sound the most careful lot tbh....
Post #502616 24th Jan 2019 11:30am
nickt68
What makes you say that tony66 Very Happy ?!!
Post #502691 24th Jan 2019 7:12pm
