Home > General > Hello with a question |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8659 |
HI and welcome, have a look in the LPG section, im sure that this has been debated before!
18th Jan 2019 4:17pm |
stu1 Member Since: 06 Dec 2013 Location: UK Posts: 276 |
Having owned both (although not on LPG), I'd say definitely the Jag over the BMW. |
18th Jan 2019 5:56pm |
RR2008HSE Member Since: 06 Jan 2013 Location: British Columbia Posts: 2932 |
I would also recommend the Jag over the BMW when running petrol. I’ve never run LPG, but I have read comments that the BMW took better to LPG. I think it was to do with the valve seats on the Jag. I think there was an additive to protect them, but a Jag conversion was harder to do right. If you don’t have the conversion done yourself, you would need to ensure that it was done properly. |
21st Jan 2019 1:02am |
Dolphinboy Member Since: 07 Dec 2009 Location: Bristol Posts: 3179 |
Hi Mike. The JAG engine is better on petrol and needs valve lube fitting if converting to LPG. The BMW is virtually bomb-proof on LPG. Mine has had it for nearly 10 years and never a problem. always get it serviced yearly.
21st Jan 2019 1:38pm |
