Home > In Car Electronics (L322) > DAB+ module that transmits 18 FM channels at the same time
Ian928
Norway 2006 Range Rover Supercharged 4.2 SC V8 Java Black
Hello all,
I live in Norway where the government decided to remove FM altogether and now all radio is transmitted via DAB+. I have been thinking about this product since then, and now a norwegian have made it.
This module is connected to your car via the FM antenna, and transmits 18 channels of DAB+, FM or internet radio at the same time via different FM frequencies. This means the radio in my 2006 SC will work as normal.
The only thing I am unsure of is that as far as I know, there are 2 antennas on the L322. Could this be a showstopper for me or will it just not use the second antenna as there is no signal?
Also, do you have any recommendations about where to connect the different inputs? The installation manual dictates that you should connect a wire to one of the positive wires on a speaker. I do not understand why. And where is this connections found? I guess you could wire into one of the speakers.
The only information I have found that are in english is the user manual, scroll down past the Norwegian...
https://bilradiospes.no/media/produktbilde...manual.pdf 2006 Supercharged
Post #501986 18th Jan 2019 11:50am
