Home > General (L405) > Help! Choice Of 2 VSEs....which to go for? |
ABAB Member Since: 02 Feb 2017 Location: GB Posts: 281 |
I have the "HUD windscreen" but have never had any issues with phone signal. Maybe I've misunderstood the post?
15th Jan 2019 12:29pm |
Red Merle Member Since: 19 Sep 2016 Location: Cornwall Posts: 2158 |
Actually, ignore the reference to the phone signal, I may have got that wrong. It’s very easy to block the relatively weak GPS signal though. My current Garmin won’t get a reliable signal signal if it’s just near the A pillar, it has to be in the middle of the ascreen - and that’s with a standard screen. |
15th Jan 2019 1:25pm |
Nooney787 Member Since: 17 Dec 2018 Location: Lincoln Posts: 26 |
Well thanks for all of your tips, I did go for car 2 in the end (MY16 65 plate). I’ve had it just over a week now and enjoying it except for the ‘whistle’ which starts at about 55 and peaks at about 75mph. The radio will drown it out but I’m damned if I’m going to put up with it on the car of this pedigree - I’m trying to help the dealer out initially by taping over various seals on the windscreen, pan roof and the roof rail trims as the noise appears to emanate from there; sourcing it will be the trickiest bit of getting this sorted out (I hope). The only other gripe is that the touch sensor on the centre interior light doesn’t seem to work - map lights are fine and the all the lights come on with door opening, you just can’t switch them manually using the touch sensitive lens - any ideas would be welcome! Other than that it seems to be a great car - I’ll post some piccys when I’ve taken a few..... |
17th Feb 2019 9:47pm |
Well thanks for all of your tips, I did go for car 2 in the end (MY16 65 plate). I’ve had it just over a week now and enjoying it except for the ‘whistle’ which starts at about 55 and peaks at about 75mph. The radio will drown it out but I’m damned if I’m going to put up with it on a car of this pedigree - I’m trying to help the dealer out initially by taping over various seals on the windscreen, pan roof and the roof rail trims as the noise appears to eminate from there; sourcing it will be the trickiest bit of getting this sorted out (I hope). The only other gripe is that the touch sensor on the centre interior light doesn’t seem to work - map lights are fine and the all the lights come on with door opening, you just can’t switch them manually using the touch sensitive lens - any ideas would be welcome! Other than that it seems to be a great car - I’ll post some piccys when I’ve taken a few..... |
17th Feb 2019 9:48pm |
Found one..
17th Feb 2019 9:51pm |
26th Mar 2019 10:57pm |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7923 |
Glad its all sorted - looks good |
27th Mar 2019 6:06am |
Looks great and while I’m a big fan of 20’s, turbines always look so good! |
27th Mar 2019 6:12am |
CUE99T Member Since: 02 Oct 2011 Location: Glasgow Posts: 779 |
Looks nice......turbines are the biz!!!!
27th Mar 2019 10:24am |
I found this video whilst browsing, checked the car and it needed the adjustment (very easy to do).......
27th Mar 2019 9:21pm |
Chalky Member Since: 10 Feb 2018 Location: Marshfield, Bath Posts: 899 |
Why do you need to do this? All LR cars from 1984
28th Mar 2019 9:21am |
Crasher242 Member Since: 07 Mar 2019 Location: Warwickshire Posts: 132 |
Unnecessary quote removed
28th Mar 2019 10:17am |
Of course if I'd had sound on, I'd have known why you do it!!
28th Mar 2019 12:23pm |
