Home > Technical (L322) > obd reader [again]
obd reader [again]
what actually can a bog standard obd2 unit do?...there are bluetooth and usb/cable types and as far as i can see they read codes and will only reset the engine malfunction light...
surely someone must have a copy of the landrover software that does the whole caboodle or is there aftermarket software that does that...
one reason for asking is that i need some light errors switching off and dont want to keep buying resistors to achieve this, another reason is that it would be nice to turn the nav on the go option amongst others.. ... - .- -.
Post #52904 4th Mar 2011 1:43pm
Have you tried a search .............................. Laughing Laughing Laughing Laughing Laughing Wink Wink ====================================
Post #52910 4th Mar 2011 1:59pm
Laughing ...i did, but i need conclusive answers not just for me but for everybody else.. ... - .- -.
Post #52916 4th Mar 2011 2:21pm
If its possible to use with an OBD2 then it would be gold dust! Thumbs Up
Post #52994 4th Mar 2011 9:25pm
Martin
Site Admin
To do anything clever you need the Land Rover system (IDS), or to be cleverer the Black Box Solutions or Autologic diagnostic kit.
Not cheap, but powerful. An OBD reader does the bare minimum as you've said - read basic faults and clear EMS warning light.
Post #52996 4th Mar 2011 9:31pm
dan_uk_1984
Navcoder allows you to change settings in the light module. Google it. I did a writeup on obd readers, it was quite comprehensive - as already suggested try search.
There is bmw software that allows a small amount of coding of modules Google pasoft and carsoft i think.
Daveo has also made good progress with some software that is nearly as full featured as testbook, but was very complicated to setup.
Dan
Post #53007 4th Mar 2011 11:04pm
Dan,
Whats the best OBD2 one to use. As you sujested the software i got with mine off the bay is pretty Censored . Could do with something better (actually works)
Post #53008 4th Mar 2011 11:48pm
dan_uk_1984
Rob2529 wrote:
Dan,
Even the most basic sw should read and clear the MIL. I use a hot version of Digimoto I torrented as it gives sensor readings too, but it's still basic.
At the end of the day an OBD reader is only ever going to reset your MIL and tell you why it came on etc. Still very much worth it, I've certainly got my monies worth.
I know the "Rover All-comms" software is nearing completion, this will be able to clear faults from all the vehicle systems. Although currently I'm unsure whether this will work so well for the later years.
Post #53011 5th Mar 2011 8:33am
@martin. you'd think that someone somewhere would have copied the official landrover software and let us mere mortals have access to it...BBS units do the lot but at £1k its to expensive for the average bloke, maybe they could produce software only products at a cheaper price..
@dan..i thought that navcoder only worked on the pre-2005 [facelift] cars.. ... - .- -.
Post #53033 5th Mar 2011 1:23pm
dan_uk_1984
Well, yes. Although I thought there was legacy iBus equipment in yours? The LCM being one of them or is it completely differnt to the BMW unit?
D
Post #53113 5th Mar 2011 9:42pm
dunno mate, having the touch screen nav i assume i have the MOST fibre optic system.. ... - .- -.
Post #53116 5th Mar 2011 9:47pm
dan_uk_1984
The LCM won't be MOST though. Only the entertainment gear ran on the MOST. The iBus ran everything in the early ones, and the legacy BMW components on the later ones iirc.
For example the PDC module runs on the iBus and is the same till about 2009.
Post #53117 5th Mar 2011 9:48pm
when we meet up for a drink you'll have to have a poke in me back Shocked and see whats what. Wink ... - .- -.
Post #53118 5th Mar 2011 9:54pm
dan_uk_1984
Well there's an offer I can't refuse!
Post #53119 5th Mar 2011 10:03pm
Laughing ... - .- -.
Post #53136 6th Mar 2011 8:44am
