Home > In Car Electronics (L322) > Rear DVD Screen Dim
Fullfat
United Kingdom 2007 Range Rover Vogue SE TDV8 Java Black
Rear DVD Screen Dim
Hi all,
I have a dim left side headrest screen, I've swapped the screen with the right hand side one and it is bright and fine.
Which tells me it's not the screen unit.
Anybody heard of this? It's dim to the point that it can only be seen if the sun is shining on it.
I was wondering if it could be the rear screen driver unit in the boot? Possible wiring? Or maybe there is a setting somewhere that I am missing?
Many thanks,
Post #500880 7th Jan 2019 6:08pm
kooky_guy
United Kingdom 2010 Range Rover Vogue SE TDV8 Stornoway Grey
Not much help, but it sounds like the backlight isn't coming on for some reason. You say it works ok when you swap to the other side? Doers the other work ok when swapped to this position?
All I can suggest is that you check all the connections. 2010 4.4 TDV8 Vogue SE
Post #500988 9th Jan 2019 8:08am
