Home > Technical (L405) > Ad Blu
peanutbob
United Kingdom 2018 Range Rover Vogue SE SDV8 Santorini Black
Ad Blu
For the first time I’ve had to add 5 litres of Ad Blu to my 2017 FFRR as it had flagged up 1500 miles left and then after another 50 miles this dropped to 1000 miles. It needed more but the 10 litres plastic canisters at the nearest petrol station didn’t have a pouring spout so would have been impossible to drop in to the small neck of the Ad Blu tank. Distance to refill now 2700 miles. Warning message then extinguished but soon after the amber engine/emissions light popped up. Reading the handbook apparently if you replenish the Ad Blu tank, then this may occur, so then you have to restart the engine 3 times leaving it running each time for 30 seconds between each restart.
Naturally this didn’t work.
It’s quite a faff this FFRR combined with the regular return to the dealer for service messages which flag up every 3k..and now on permanently but apparently cannot be extinguished until it is actually serviced at the correct time/mileage.
Post #500029 30th Dec 2018 12:00am
Bill
I was flummoxed by ad blu before some said it’s just like adding screen wash!
I tend to put in 10L at a time & the light goes away.
Some ad blu packs have spouts set into the frame of the 5L bottle.
I also fill up prior to a service , then I don’t get smacked for that as an additional item.
Bill Filters are in fact so good that in certain circumstances, when the ambient air is already polluted, a diesel car will tend to extract more particles from the air than it emits. Emissions Analytics worked with........etc etc
He who dies with the most toys wins...
Post #500098 30th Dec 2018 5:43pm
Dixy
2016 Range Rover Vogue SDV8 Loire Blue
You may find search a useful tool https://www.fullfatrr.com/forum/topic39769...t=add+blue
Get one of the big (I think 25 litre) bottles and fill up. The sensor does not recognise a bit being added and the car has hissy fits.
It is so disappointing that sales staff are still not explaining this properly on hand over. letters not necessarily in the right order
Post #500156 31st Dec 2018 9:33am
peanutbob
Thanks for the info. I’ll put more in today...but it’s not the Ad Blu message that is still on - this disppeared immediately but the engine management light/emissionsamber light which is on. Acc to the handbook to make this disappear one has to restart the vehicle 3 times in quick succession of 30 seconds running each time.
Anyway will fill the tank and see if this helps!
Post #500167 31st Dec 2018 10:39am
jim4244
England 2005 Range Rover Vogue Td6 Zambezi Silver
I was told that when topping up the adblu on a L494 that the ignition had to be turned or the engine had to be running on whilst refilling.
Not sure if this is also the case on the L405?
Jim
Post #500168 31st Dec 2018 10:42am
Bill
No need for ignition to be on Filters are in fact so good that in certain circumstances, when the ambient air is already polluted, a diesel car will tend to extract more particles from the air than it emits. Emissions Analytics worked with........etc etc
Post #500250 1st Jan 2019 4:24pm
peanutbob
I put another 5 litres of ad Blu in and still the engine management light has stayed on.
Post #500251 1st Jan 2019 4:33pm
chugga90
Lend it to Sharon Davies, she will fix it! Whistle
Post #500261 1st Jan 2019 5:49pm
peanutbob
I had to look this up as I thought you meant Sharon Davies the swimmer which got me a bit confused....and I’ve never watched an episode of Neighbours Shocked Shocked
Post #500266 1st Jan 2019 7:33pm
Red Merle
United Kingdom 2017 Range Rover Autobiography SDV8 Aintree Green
Laughing
Post #500272 1st Jan 2019 9:19pm
rjff
the swimmer's ex Razz Cheers
Richard
Gap IIDBT
Post #500275 1st Jan 2019 10:22pm
