Home > Technical (L322) > Help needed with heated seat fault
Katash
England 2007 Range Rover Supercharged 4.2 SC V8 Zermatt Silver
Hello,
My 07MY SC drivers seat had stopped heating (I'm not sure if cooling is working either) I'm getting the following fault with IID Tool
SCME-DrivSeat Climate B1156-7A (28) Driver's seat - Mechanical failure - fluid leak or seal failure
It appears the fans are blowing but getting no heat, I reset the code and it immediately came back, reset a second time and has now stayed gone but still no heat.
Presumably something to do with the peltier cell - is there anything on them filled with liquid that would tie in with the leak mentioned above?
Hoping someone may have had similar issue and could shed some light on it
TIA
Post #499464 22nd Dec 2018 11:04pm
The seat heating/cooling peltier cell rely's on pressure to work, usually the plastic ducting breaks and this means a pressure loss and the system shuts down!
Pop the rear cover off the seat and inspect the ducting. My guess is it will be split open! They are very expensive to replace!
Post #499466 22nd Dec 2018 11:16pm
Katash
Yea, just found a thread with lots of pics of broken pipework, best I get filters removed and checked before I do too much surgery and if it is a goosed pipe hopefully it can be patched as others have.
Post #499467 22nd Dec 2018 11:29pm
