![]() | Home > Technical (L322) > Upper tailgate corrosion |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3979 ![]() ![]() ![]() |
Surely if it's only a few months ago and a couple of thousand miles since the repair was carried out it indicates the job wasn't done properly and the dealer should be given the chance to do the job properly before you should be considering tailgate replacement.
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8750 ![]() ![]() ![]() |
I had mine done on my 12 plate, a couple of years back by Chartwell in derby. They replaced the panel, which is what should be done under the corrosion warranty.
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1401 ![]() ![]() ![]() |
Having had a tailgate replaced under warranty and then having to have the replacement treated and painted after about a year again on a 2012 WM (starting under 3 yo) but the tailgate on a 2004 car having only the odd bubble after almost 10 years, my theory is that the newer cars either used poorer steel with more recycled content or less protective paint (perhaps due to changed environmental regulations).
MR GLOVER Member Since: 03 Jan 2015 Location: grimsby Posts: 605 ![]() ![]() ![]() |
No corrosion on my 55 plate , just the rear wheel arches. try getting one of an old one |
Lester Burnham Member Since: 12 Sep 2018 Location: North Posts: 116 ![]() ![]() |
Cheers all for your replies/sympathy..
Rapiscan Member Since: 28 Apr 2018 Location: North Lincolnshire Posts: 182 ![]() ![]() ![]() |
My Dec 2007 Tdv8 had very minor corrosion on the front of the rear wheel arches,none elsewhere on the body,both tailgates are immaculate.Seems pot luck whether you end up with a goody or a lemon. 2008 L322 Vogue 3.6 TDV8 in Java Black with parchment and Navy interior. 125000mls.
