![]() | Home > General > Why L405 over an L322? |
160dmb Member Since: 16 Dec 2012 Location: Hertfordshire Posts: 455 ![]() ![]() ![]() |
I have recently traded an 2011.5 L322 VSE for a 2014 L405 VSE and I have to say my L322 was near perfect for a 100,000 mile car - I am fastidious and had replaced all the suspension parts that wear and the 2011.5 VSE I sold was as good as they get - the 75,000 mile L405 I have bought is still work in progress but it’s better in almost every regard. they come from the same first owner who is a friend who looks after his cars but changes them when the miles rack up - as they do for himself this is a fair comparison.
dolph34 Member Since: 14 Sep 2015 Location: Kildare Posts: 1724 ![]() ![]() ![]() |
Wow !!! Is that the general ' have-nots' or specific 'have nots'. Your mileage or driving experiance in FFRRs is completely irrelevant to how other opinions are formed, some of us 'have nots' are able to form our own opinion based on our own experience. Good to see people able to end a friendly discussion with a ' superior' opinion though , saves all of us ' have nots' the effort of posting. To the original poster, the offer from Cam Tech Craig seems a very sensible ( and generous ) way for you to make up your own mind of what suits you the best. Thats if you need to make your own choice if other much , much wiser and more informed people think its ok for you to decide for yourself as you are technically a ' have not ' at present. ![]() GSXR 1000 K5 R1 1998 |
The example offered here is, again, not about an L405. Before and after buying our car, research undertaken as to what engine to go for was extensive. In contrast, the LR main dealers we have used (3) have said they do not have experience of the L405 regularly presenting with engine failures, in fact they said they had not experienced it in the 3.0 L405 (they had with the Discovery). Perhaps others on the forum will be able to cite main dealers who have experienced this on the L405. The fair thing with posts like these is for there to be a mixed and balanced response that let's those asking the questions make the best informed decisions. Below are 3 different L405 threads from this year. 2 relate to 4.4 diesel engine failures and 1 about a 3.0. In one example, a 4.4 engine apparently failed at speed on a road which the OP reported was worrying. Worthy of note if tending to suggest high speed engine failure would be a specific 'safety' risk of owning a 3.0. Cars break down. They experience unforeseen failures when stationary and at all speeds. Personally, I would not have an LR of any type without a warranty. Again, that's not a view shared by everyone it's just that if things go wrong and you are mechanically limited, then it's that wee bit peace of mind (for me at least). From a strictly 'safety' consideration, what would you think more probable with the L405, the risk of a high speed tyre blow out and resultant loss of vehicle control, or the engine failing at high speed (if a tyre blow out more probable, does it put you off driving them at speed)? https://www.fullfatrr.com/forum/topic48947.html?highlight=engine https://www.fullfatrr.com/forum/topic47796.html?highlight=engine https://www.fullfatrr.com/forum/topic47777.html?highlight=engine Last edited by pld118 on 23rd Dec 2018 6:49am. Edited 1 time in total |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3550 ![]() ![]() ![]() |
Link #3 seems to be about a V6 . Cheers, Greg - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 2011 Vogue SE 4.4 with lots of toys in Stornaway |
Balance |
I've driven a 2018 SDV8 405 then got back into my 2011 322 without any feelings of want.
Red Merle Member Since: 19 Sep 2016 Location: Cornwall Posts: 2158 ![]() ![]() ![]() |
Except that the TDV6 is also built by Ford (at Dagenham), while the TDV8 is built by Ford (at Chihuahua) and was developed from the same Ford/Peugeot/Citroen “Lion” V6 design. I’ve owned two SDV6’s (in D4’s) where they were great engines. The oil pump was sorted many years ago, but snapping cranks crop up from time to time. No one knows how many for sure, it’s all the subject of rumour and speculation. I’ve had one serious problem with my own SDV8, which resulted from an oil leak escaping along the wiring harness that links the oil sensor, inside the engine, to the main loom, allowing oil to drain along the cable and in to the electronics of the primary turbocharger - resulting in all manor of fault codes and a yellow engine light of death. It needed a modified wiring loom (7 hours’ labour!!) and a new turbocharger. Fortunately, as a 2017 car, it was all done under warranty. Apart from that, it’s a great engine ![]() |
MR GLOVER Member Since: 03 Jan 2015 Location: grimsby Posts: 605 ![]() ![]() ![]() |
Am a ( have-not ) will stick with me l322 until it dies i think ........ |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8680 ![]() ![]() ![]() |
I would class myself as a have no 405. They are just getting to the point where I'm just starting to get tempted. However im yet to drive one so cannot offer a relevant opinion as to how good they are.
Good balance from RM and NMJ |
Andy S Member Since: 16 Jun 2013 Location: Sevenoaks Posts: 1041 ![]() ![]() ![]() |
I had my 2010 L322 3.6 VSE for 4 years and it was the best car I’d ever had. Stupidly chopped it in for a brand new Jag F Pace 3.0 V6 which I shipped out after 53 weeks of ownership for a 4.4 2015.5 L405 VSE, which I loved from the minute I sat in it. Which is better? The 405 is smoother, faster, and lighter, but no more luxurious. The lights aren’t as good - surprisingly - but in most respects its a nicer car and is now the best car I’ve ever had. So yes, in my view the 405 is better, but they are more expensive, so if you have a good late 322, hang on to it whilst saving for a nice 405. Took me 6 months to find mine.
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1393 ![]() ![]() ![]() |
Another point: the towbar options on the 405 are better, I have the detachable farmer's hitch one and it is simpler and sturdier than the Westfalia style one on the 322, which was prone to seizure of the release mechanism. The 322 has a more convenient approach to storage around the cabin, and early 405s have the seat heating 'through the screen' which is more fiddly and takes attention off the road for longer.
Emperor Mong Member Since: 07 Jul 2010 Location: London Posts: 1435 ![]() ![]() ![]() |
I was a multiple L322 owner. I have been a L405 owner for 4 years. About to trade my current one in for a new one.
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16312 ![]() ![]() ![]() |
Couldn't agree with E M more |
