Home > Technical (L322) > locked out
Nice but dim tim
United Kingdom 2003 Range Rover Vogue 4.4 V8 Zambezi Silver
locked out
HELP. MY 4.4 V8 03 vogue, has locked me out of the car and then refused to acknowledge the key buttons, so thinking the battery flat used grey socket on tow bar to recharge it, but battery fully charged ??. And key just turns in the drivers door lock ??. So Censored Censored HELP PLEASE Bow down Bow down
Post #499258 20th Dec 2018 12:45pm
Battery in key fob ? .
Post #499259 20th Dec 2018 1:00pm
Baltic Blue
Tip of the day... Duracell batteries work best in key fobs.
Post #499264 20th Dec 2018 2:41pm
Nice but dim tim
Key fob battery changed twice Thumbs Up ?
Post #499270 20th Dec 2018 4:17pm
First post and you want to know how to get into a locked FFRR, hmmmmmmm. Whistle
Post #499271 20th Dec 2018 4:19pm
Without a key or a lock that won't work, it is nigh on impossible without causing some serious damage to a door or breaking glass. ( I know I tried when I locked my keys in the car) Had to buy a new key (my lock worked OK)
And just breaking the glass on the little window on a rear passenger door may not help. If the car is super-locked, the inside door handles may not unlock the door. .
Post #499274 20th Dec 2018 5:06pm
Nice but dim tim
Cheers joe I think you may be right about smashing the drivers window Exclamation Exclamation. I was thinking about getting the bonnet and disconnecting the battery ?, would that reboot the cars system and let my in to my car Rolling with laughter Question Question
Post #499279 20th Dec 2018 6:36pm
mjdronfield
Take it you have tried holding the unlock button down on the fob to see if all the windows come down? You get the red light on the key when you press the button?
Long shot I know.... just thinking of the easy stuff.... 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #499281 20th Dec 2018 7:09pm
rik
Scotland 2003 Range Rover Vogue 4.4 V8 Bonatti Grey
How can you tell battery is fully charged ?Mine did that when I left side lights on all night had to jack car up and connect battery pack to starter motor connection then she unlocked no prob .My key would also not unlock drivers door at the time so I fixed it so I would not get caught again good luck
Post #499283 20th Dec 2018 8:23pm
Nice but dim tim
Cheers mjdronfield and rik, just had a go at press and hold unlock button, no joy Censored Censored will have a go at starter motor tomorrow cheers lads. Thumbs Up Thumbs Up
Post #499286 20th Dec 2018 8:47pm
holidaychicken
How did you charge the battery via the towing connection as that should be connected to an ECU
How do you know the battery is fully charged and as above are you getting the red light on the key fob?
The only way I know to get power to the battery is to get underneath and carefully put 12 volts to the starter cable.
Post #499294 21st Dec 2018 2:03am
^ There are two direct feeds from the battery, albeit through fuses, to the rear tow sockets which can be used to charge the battery. These two don't go through an ecu. Thumbs Up
Post #499297 21st Dec 2018 6:05am
holidaychicken
Every day is a school day Very Happy
Post #499302 21st Dec 2018 8:16am
GraemeJudge
2004 Range Rover Vogue Td6 Java Black
I have also put an Anderson connector to the jump start point and mounted it on the front bumper on with a cover allowing me to put a multi meter across and check the voltage of the battery and make it nice and easy to jump start if needed,
this is the same on my dads (nice but dim tim) so that's how we know battery is fully charged
Post #499303 21st Dec 2018 8:21am
The forum offers a made up CTek charger connector to the trailer socket.... (see Shop)
Post #499306 21st Dec 2018 8:42am
