Home > Technical (L322) > L322 Central Locking
ricky25
United Kingdom 2003 Range Rover Vogue Td6 Rimini Red
I have a problem with the central locking on my 2003 (L322) RR Vogue. It all works as it should apart from the driver’s door not unlocking with key fob. When the key is pressed I can hear a “clunk” noise in the door. The driver's door can be opened by inserting the key into the lock. If using the dashboard locking button, all doors lock and unlock apart from the driver's door. I think I can deal with dismantling the door myself but need to know in advance which replacement parts to buy. Your help and advice would be much appreciated please.
Post #499031 18th Dec 2018 2:09pm
tony66
Scotland 2005 Range Rover HSE Td6 Tonga Green
parts
i wouldnt buy anything until you explore what is going on inside the door tbh,could be a clip or anything...
Post #499033 18th Dec 2018 2:16pm
ricky25
Thank you for such a prompt reply. I'm a bit reluctant, however (as an amateur) to strip the whole door panel down then potentially have a time lag before I can reassemble it and use my vehicle again.
Post #499034 18th Dec 2018 2:22pm
annette
A Trap
Don't worry you can drive it with the panel off, we do it all the time when testing client's cars.
here is the trim
http://new.lrcat.com/#!/12119/101499/101771/8066
and what is lurking inside
http://new.lrcat.com/#!/12119/101499/102862/8142/102885
the rod is a suspect! If it has cables or chips it is usually my nightmare. I am in Costa Rica Please update your drop down list
Post #499038 18th Dec 2018 3:01pm
ricky25
Very helpful - thank you !
Post #499040 18th Dec 2018 3:16pm
ricky25
Is it necessary to disconnect the battery first to "protect" the door airbag ?
Post #499072 18th Dec 2018 8:41pm
tony66
bag
only if you want to disconnect it...if not you could pull the fuse/s thats what i used to do on my e53 x5[similar systems]
Post #499075 18th Dec 2018 9:04pm
LASBAM
Germany 2007 Range Rover Vogue TDV8 Orkney Grey
L322 MY2006 Central Locking not working
Hello together,
i have a similar issue:
- central unlocking by driver door not working-only unlocking the driver door
- key remote not working at all - i can manually unlock the driver door and then need to press the button in the dashboard
- re-sync of the keys to the central locking not working
- wire-harness in driver door is checked and fine - every connection is working
- if using the dashboard locking button all doors lock and unlock apart from the driver's door.
You have any ideas what could be the issue?
Suggestions highly welcome! Current:
- 2006 RR L322 - 3.6 TDV8
- 2022 MB AMG GT BS
- 2020 Audi Q2
Past:
- Ferrari California 30
- 2018 Abarth 595 Competizione
- 2009 Porsche Cayenne Diesel
- 2010 MB E500 Coupé
- 2005 Porsche 996 Turbo
- 2002 Porsche Boxster 986 S
- 2001 Audi S8
Post #655850 6th Feb 2023 6:37pm
