Home > eBay & Bargain Spots > Seen any battery deals?
GGDR
My wife's Toyota battery has been pronounced dead.
Found the invoice was a Varta, lasted just under five and a half years. I suppose not bad.
Anyone seen any offers, codes etc out there?
Cheers!
. Cheers, Greg
Post #498822 16th Dec 2018 4:05pm
AJGalaxy2012
Get yourself a trade card from Halfrauds, brilliant, good discounts inc batteries, I got £45 discount on a £180 battery.
GSF and Eurocarparts are also doing discounts with their codes at the minute. BMW i3 Electric Car
2006 VW Touareg 3.0 TDi V6
Post #498823 16th Dec 2018 4:15pm
Bradders
United Kingdom 2012 Range Rover Westminster TDV8 Zermatt Silver
^^^ 45% off batteries at ECP at the mo';
https://www.eurocarparts.com/car-battery Current: FF Westminster money pit
Gone:
RRS 4.2 SC
RRS 3.6 TDV8
FL2 TD4
Post #498826 16th Dec 2018 4:26pm
jim4244
England 2005 Range Rover Vogue Td6 Zambezi Silver
How easy is it to get a Halfords Trade Card?
Jim
Post #498830 16th Dec 2018 4:45pm
AJGalaxy2012
Dead easy, apply on line.
Qualifying trades:-
Qualified mechanic
Self-employed mechanic
Mobile mechanic
Small independent garage mechanic
Fast Fit Centre mechanic
Commercial vehicle mechanic
Police, fire or ambulance mechanic
Bus mechanic
Local authority mechanic
Recovery mechanic
College motor vehicle staff
College apprentice mechanic
Army mechanic
RAF or aviation engineer
Railway engineer / mechanic
Naval Engineer
Marine Engineer/Mechanic
Carpenter
Electrician
Plumber
Glazier
Landscaper / Fencer
Welder / Metal worker
Utilities worker
Taxi companies & drivers
Courier companies & drivers
Make yourself a business card, job done! BMW i3 Electric Car
Post #498831 16th Dec 2018 5:02pm
I always find the best selection and prices at tayna.co.uk .
Post #498833 16th Dec 2018 5:16pm
Swipe
United Kingdom 2004 Range Rover Autobiography Td6 Java Black
Just had to stick a new Bosch s5 on the Td6 today asap, had to go to ecp £162 with their discount code. Previous S5 was nearly 4yrs old, dead as dodo after charging wouldn’t turn over.
New battery in started straight away plus no “HDC INACTIVE” so all good.
Post #498919 17th Dec 2018 2:41pm
GGDR
Thank chaps.
I went with Tayna. Best price I could find. Got a Varta with a 4-year warranty.
Problem with ECP or GSF is their list prices are astronomical to begin with. So a 45% or whatever discount sounds good, but does not really compute.
I also find their websites pre-filter everything based on your car. Which isn't always right.
Eg I want to go from an AGM 019 battery to an AGM 020 battery for the Range Rover, but their websites won't show anything they think won't go on your car. Granted that's well intended - the 020 needs it's based plastic trimmed to fit.
But I can't do a product only search easily. And their list prices are just a turn off.
. Cheers, Greg
Post #498920 17th Dec 2018 2:53pm
SandySix
United Kingdom 2007 Range Rover Vogue TDV8 Stornoway Grey
I find that sometimes if you type in 019 battery it will take you to the right place.. but seems a bit variable!
Just got a Bosch for my partner's Clio from ECP.. with the discount at the time it was £3 more than Tayna, but as local to a shop it was delivered within an hour for free! With Tayna it was another £8? for delivery!
Also if you need to return, ECP are easy to get to and generally just say 'OK we will exchange it' With Tayna it is never that easy.. need to return it, wait for them to test, then see if they accept it is dead.. I need the car back on the road not waiting on the drive for a battery!
However if you have no problems, Tayna are OK!
Post #498921 17th Dec 2018 3:08pm
dingg1
What he posted.
Tayna good if all goes well but if the battery fails ( mine did first time ever buying from them) watch out for the warranty it aint worth much as its quite hard to find a courier to take it back to them.
I just ended up writing the battery off after only 16 months
Post #498922 17th Dec 2018 3:12pm
Bushy30
United Kingdom 2011 Range Rover Vogue SE TDV8 Galway Green
Greg,
an 020 won't fit in your machine -- well not without disconnecting or rerouting the scuttle drain!
I know, I tried! -- the large connector on the side of the battery +ve terminal simply doesn't fit :O
Bushy Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
2004 FFRR Vogue 4.4 V8 with LPG
1997 P38 4.0 SE with LPG
1997 P38 4.6 Vogue with LPG
Post #498923 17th Dec 2018 3:31pm
