Home > Maintenance & Mods (L322) > Leaking steel brake lines to the rear fix
Page 2 of 3 <123>
Simes
United Kingdom 2011 Range Rover Autobiography Black TDV8 Barolo Black
Always remember to fit the nut (the right way round) before flaring the pipe...
How you laugh when you see the perfectly routed pipe is in place perfectly aligned and the baleful looking nut is facing up the pipe instead of down...
Post #498243 11th Dec 2018 8:52pm
Or my way, (did it twice) flare the second end of the pipe then look down at the nut sitting on the bench in front of me Rolling with laughter
Learnt to allow an extra inch of pipe after that Smile .
Post #498256 11th Dec 2018 11:39pm
doclees
United States 2004 Range Rover HSE 4.4 V8 Java Black
Yeah I've been watching different bending and flaring videos and they all remind you about the fittings yet some still forget. That flaring tool seems to be made in Taiwan and sold here in the US under Titan Tools and Eastwood Automotive labels. Seems to be the best design for a dedicated 3/16 in on the vehicle flaring tool.
Post #498266 12th Dec 2018 3:11am
Clive603
England 2004 Range Rover HSE Td6 Orkney Grey
The important issue with flaring tools is that they have a firm but gentle and non marking / non distorting grip on the pipe so that the flaring end has a firm base to work against. I have a couple or three about the place two bought, one inherited. First one I got was on the "not going to do many so don't spend too much" basis. Not the cheapest but looked to be best of the less than expensive designs. Mistake as it barely held well enough and proved very sensitive to tube diameter. Just about OK on proper kunifer but unhappy on "factors brand"same-as-kunifer and copper.
Yup. Ended up doing more than the couple of and odd jobs I expected! So when a pro version came up on E-Bay at £ very, very reasonable I bit. Used it once in 5 years. At least the other two means the good one never becomes a loaner.
When you are saving money by DIY its wise to invest some of the savings on proper tooling. Especially these days when most tools are relatively cheap compared to labour costs. If its a job you don't do often or something you are not in practice with the last thing you need is a balky or hard to drive set-up.
Clive
Post #498283 12th Dec 2018 11:13am
doclees
Just want to confirm that the double flare is the only type of flare needed for this repair. No bubble flares needed for the line to flex hose connections?
Post #498980 18th Dec 2018 2:56am
RRV78
England 2003 Range Rover Vogue 4.4 V8 Java Black
Everything is just double flared all around the car! Current: 16 my2016 Range Rover l405 4.4 sdv8 Aruba gold & 11 MY2011 RANGE ROVER L322 4.4 TDV8 ZERMATT SILVER
Previous
59 MY2010 Range Rover Vogue L322 3.6 TDV8 Zermatt Silver
53 Range Rover Vogue L322 4.4 V8 Java Black
98 P38 Range Rover 2.5 DSE Champagne Gold
Post #498983 18th Dec 2018 6:25am
doclees
Excellent! OK off to Land Rover to get the spring clips and then off to my mechanic.
Post #499029 18th Dec 2018 2:44pm
RRV78
Now if your talking about the spring clips on the front pipes between the pipe and flexi you may struggle.
My local delear told me they were discontinued and our site sponsor dan at duckworth’s couldn’t help me either so had to reuse my old ones. Current: 16 my2016 Range Rover l405 4.4 sdv8 Aruba gold & 11 MY2011 RANGE ROVER L322 4.4 TDV8 ZERMATT SILVER
Previous
Post #499030 18th Dec 2018 2:51pm
Strider
The black pipe clips in pic below I re-used then formed the pipes and pressed them into the recess, didn't use the clips as a forming aid felt they would break if I did.
Post #499035 18th Dec 2018 3:24pm
RRV78
I wanted to replace these but my dealer said there discontinued
Previous
Post #499041 18th Dec 2018 4:31pm
Strider
Yes, I had the same problem but contacted Martin at AYLMER (01707 665588) and he was able to get me 2.
The part number is :- SGK100670L , I did a quick search and found a couple of suppliers for you. I dont know if they have got any (£3.50 each).
https://www.brit-car.co.uk/product.php/129...over_vogue
https://www.johncraddockltd.co.uk/land-rov...-clip.html
Good Luck
Post #499057 18th Dec 2018 8:05pm
RRV78
Thanks but jobs long done now fortunately I managed to clean mine up and reuse them. Current: 16 my2016 Range Rover l405 4.4 sdv8 Aruba gold & 11 MY2011 RANGE ROVER L322 4.4 TDV8 ZERMATT SILVER
Previous
Post #499059 18th Dec 2018 8:25pm
doclees
Thanks guys. My dealer has ordered them for me at $9.50 each. I think I am going to cancel that order. They look the same as BMW clips for $.97 each. Thanks for the picture to confirm that.
Post #499062 18th Dec 2018 8:36pm
doclees
BMW part and number. Look familiar?
Post #499104 19th Dec 2018 4:31am
Strider
10/10 Thumbs Up
https://www.eurocarparts.com/ecp/c/Porsche...amp;000030
Post #499150 19th Dec 2018 2:14pm
Page 2 of 3 <123>
