![]() | Home > Maintenance & Mods (L322) > New Jack? |
AA/RAC Membership or LR Assistance....... |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35476 ![]() ![]() |
what gaz says...the RR jacks are rubbish, mine bent on its first outing....there's no solution other than carrying a 3 ton trolley around with you..
JW911 Member Since: 09 Dec 2008 Location: Hampshire, UK Posts: 251 ![]() ![]() |
It's more just for swapping winter and summer tyres. The onboard spare was replaced with a can of Tyreweld when the LPG tank was fitted. 2021 3.0 P400 Vogue
MrP Member Since: 28 Apr 2010 Location: West Sussex Posts: 471 ![]() ![]() ![]() |
Currently thinking the same - I have got an 8 ton bottle jack and in the official jack points just raises the car but not enough (quite) to clear the wheel you want. however I have just found this 12Ton bottle jack that lifts to 465mm - anyone got access to the official RR jack and can measure the lifting height of that to compare?
i think the required lift is around 500mm to clear the wheels of the ground...just a thought, how about putting the range in access mode and leaving the door open so that it wont self level, anyone tried this?. ... - .- -.
A bottle jack is OK as long as you can position it under the suspension arm, easy on the rear - not so easy on the fronts though.
Don't forget to put the car into "Offroad" height and then open the boot lid.
47p2 Member Since: 05 Oct 2010 Location: Gone Beyond, Subaru Posts: 8048 ![]() ![]() |
I use a trolley jack which was my fathers and must be at least 40 years old. It has a lifting capacity of 3 tons and maximum lift of 22" (56cm). I also have a 20 ton bottle jack with a maximum lift of 20" (51cm) I also place a piece of timber between the jack and the vehicle to prevent slippage.
New plan - instead of trying to lift the entire body by using the official jacking points (how much articulation is there in a RR!!) I'm going for the 'jack under the axle' approach. "On first name terms with my local Dealer......now."
best way, i have a 3 ton trolley jack in the garage and will rely on the breakdown service to jack mine up to fit the spare...
elpeede Member Since: 09 Mar 2010 Location: Staffordshire Posts: 713 ![]() ![]() ![]() |
I always use the trolley jack under the relevant lower suspension arm.. suitably protected to prevent damage. ![]() Previous Landrover products -1990 110 TDI CSW, 2003 TD6 Vogue - RRC TD Vogue, RRC v8 Fleetline, Disco ES V8 LPG, 101 Ambulance "Morph", 1964 SIIa Auto Powered by Jag 4.2 Lump - "Percy". |
nick h Member Since: 26 Jan 2011 Location: notts Posts: 782 ![]() ![]() |
trolley jack from machine mart (high lift) but was told by my mechanic to always use a block of wood as a 'cushion' |
Reminder ![]() |
