Home > Wheels & Tyres > Will 275/55/20 fit on L405 with 20x8.5J? |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7925 |
I'm far from an expert on these things..... however, standard is 275 40 22 but Craig is running 295 40 22's on standard wheels - compared to 295 40 22 - the 275 55 20's would be 0.6" taller - which is 0.3" each top & bottom. They would also be 0.8" narrower - so 0.4" either side - so assuming the ET thing is mm - then they shouldn't rub.....
7th Dec 2018 8:13pm |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3739 |
285/50/20 Cooper AT3, just touch ever so slightly on std ET47 wheels, your friends wheels are ET 57, which is 10mm further in.
7th Dec 2018 9:27pm |
