Home > General > 3.6 TDV8 how common is turbo failure |
speedymarktd6 Member Since: 20 Nov 2008 Location: Worcestershire Posts: 727 |
I don’t think there’s a specific problem with them failing but you need to bear in mind most turbos will let go at 100K-150K
3rd Dec 2018 9:17pm |
bob-lad Member Since: 12 Jun 2015 Location: Herefordshire Posts: 92 |
I know it's the single system, not the twin turbos on the 3.6, but the turbo on my D3 was still the original when the engine let go at 250k. |
4th Dec 2018 8:31am |
rar110 Member Since: 09 Aug 2014 Location: Brisbane, Australia Posts: 1119 |
Turbos are generally expected to last the life of the motor. My 3.6 has 281,000km, and the motor runs beautifully.
4th Dec 2018 8:54am |
HS66 Member Since: 22 Jun 2016 Location: Surrey Posts: 73 |
Thank you all.
4th Dec 2018 8:33pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8662 |
3.6 is a good motor, and they can go on for miles without the turbos letting go, or they can go bang at 100k.
4th Dec 2018 8:45pm |
sako243 Member Since: 26 Dec 2013 Location: Wales Posts: 612 |
Mine was on 168k on orginial turbos and was running fine when I sold it 6 months ago
5th Dec 2018 8:52pm |
Zeb Member Since: 04 Oct 2016 Location: Lincolnshire Posts: 134 |
Mine now has 145k miles on the original turbos and sounds and feels like new..
6th Dec 2018 7:34pm |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3754 |
A Turbo will last the life of an engine if looked after, allowed to spoil down, idle before shut off and regular oil changes - tell tale signs are blowing oil.
6th Dec 2018 8:02pm |
Turbos are definitely cheaper than an engine for sure, not a cheap job to replace for the sake of it tho. There is nothing that can't be fixed with a hammer😜😜
6th Dec 2018 8:13pm |
Think I’m going to hold off a couple more months and go for a 4.4 instead, from what I’ve seen they’ve got much less chance of going pop on them, and the 8 speed gearbox seems to be less troublesome too. |
9th Dec 2018 11:17am |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16302 |
That makes a LOT of sense sir... The 4.4 (in standard form) is a much better buy imho... |
9th Dec 2018 12:35pm |
Andy Member Since: 23 Feb 2009 Location: Shropshire Posts: 2938 |
I’ve been told to avoid the 4.4 - cranks snap apparently |
3rd Mar 2019 3:49pm |
dolph34 Member Since: 14 Sep 2015 Location: Kildare Posts: 1724 |
Who ever told you this must be avoid at all costs, they know little of which they speak 2015 4.4 AB
3rd Mar 2019 4:04pm |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7831 |
I had a small loan to skip the 3.6 and get the 4.4.....
3rd Mar 2019 5:13pm |
