![]() | Home > Camping, Caravanning and Holidays > Switching from single axle to twin |
AJGalaxy2012 Member Since: 11 Jun 2018 Location: Gainsborough Posts: 1464 ![]() ![]() ![]() |
Towing a twin is a dream, manoeuvring by hand nigh on impossible, reversing on the car no problem, no different to a single axle BUT a motor mover is pretty much essential (even if you can reverse).
Huwrhys Member Since: 07 Feb 2018 Location: Hornchurch Posts: 548 ![]() ![]() ![]() |
What he said ^ |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8747 ![]() ![]() ![]() |
Yes fitting 2 locks is a pita, but there is a knack, involving a small bottle jack......👍🏻
Small bottle jack isnt worth the hassle, just pay £15 per year not to have the second lock. If you use the jack, how does it work on a slope i.e. you need the handbrake on so you cant turn the wheel anyway. BMW i3 Electric Car
agree paying the 15 extra is the easiest way to go. and no you can't do it on a slop, as the caravan will roll off....... There is nothing that can't be fixed with a hammer😜😜
IanV8 Member Since: 14 Jan 2010 Location: Dunfermline Posts: 502 ![]() ![]() ![]() |
Get the E&P self levelling fitted, dead easy to raise both wheels and makes setting up dead easy. I’ve had it for over 3 years now and won’t have a van without it in the future.
TJH1985 Member Since: 11 Feb 2015 Location: Nottingham Posts: 664 ![]() ![]() ![]() |
Twin axle Swift 645 Elegance here - its a dream to tow! No comparison to single axle as everything we have towed has been twin however.
SinbadRose Member Since: 21 Aug 2017 Location: Merseyside Posts: 114 ![]() ![]() ![]() |
Hi,
You cant leave a mover on with auto engage!
Our old Wyoming had an auto, and you are right, but ours is manual, picked it for this reason, as well as being quicker to put on and off, but then again, the auto one we had had done a number of miles and a number of years, so could be a factor. |
V8 Bob Member Since: 15 Mar 2018 Location: Cumbria Posts: 374 ![]() ![]() ![]() |
Biggest issue maybe where you store the van. I need to spin mine through 180 degrees in the yard which is just over 5ft wider than the van is long single axle is fine on the mover but mate says he couldn’t do same with his twin axle as it “jumps” and would take multiple goes to achieve what is basically a single movement with the single axle. Agree towing is better with a twin axle from previous experience. |
stu1 Member Since: 06 Dec 2013 Location: UK Posts: 276 ![]() ![]() ![]() |
Thanks folks - some great info and tips |
You may have issues in a very tight space as the wheels are turning against each other, so it causes the tyres to bulge out in different directions. If on a good surface, you could use the jock wheel to raise the front a little to help off set it, but then you are not getting all four wheels working fully, but it can be done. |
The way movers work on AWD systems is the outside pair run continuously whilst the inside ones pulse on then off. This reduces the binding /locking up of the wheels by running in a forward motion whilst turning. Single axle vans will spin within their own length as no tyre scrubbing occurs. Despite this issue I have never been anywhere I couldn't get out of and I've covered a hell of a lot of sites all over Europe. The Italian sites can be very tight but even so I've maneuvered the van within inches of trees and obstacles with the movers without any real drama at all. Don't concern yourself about putting the van where you want, FFRR are by far the best tug you'll find anywhere on this earth and will direct your van wherever you need it. The movers will do the stuff your car can't. Jobs a goodun.
