![]() | Home > Maintenance & Mods (L405) > L405 SDV8 BATTERY DRAIN |
Charles89 Member Since: 11 Nov 2018 Location: Leicester Posts: 268 ![]() ![]() ![]() |
Well...
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35552 ![]() ![]() |
stop/start does take its toll on car batterys and AGM [absorbed glass mat] batterys can take the strain especially if theres current input from braking regeneration involved ..
The thing is.. I don't even have stop start! It's either on or off.. non of this traffic light nonsense |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3789 ![]() ![]() ![]() |
Their is a thread on here somewhere that suggests that if you get the click click no start problem on an L322, switch the windscreen wipers on and off and then try again.
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16332 ![]() ![]() ![]() |
If your car does not have stop start, why would your local garage tell you it needs that battery?
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1397 ![]() ![]() ![]() |
You might have a problem with the locking software that causes a battery drain. That happened on my last 322 (TDV8). The software was reprogrammed (by dealer) and the battery tested after it had been fully recharged, to see if it had been fatally damaged by the total discharge (apparently the test can only be done with a fully charged battery). It had been and was replaced. All done under warranty. No point in throwing batteries at the car if the drain has not been stopped. Only Range Rovers since 1988 |
Ah thank you for this information! I was not aware the module can be updated and possibly fix the issue.
So apparently I have a soft closure module that needs changing sling with a new door lock and possibly Handel. Keyless entry is keeping the car awake and causing a drain |
Not sure why "fitting bigger batteries is not the way to go" Charging the battery is only a minor part of what the alternator does. Most of the relatively large electrical load on the car runs directly off the alternator once the engine is started. I have two 110AH batteries connected in parallel on my car giving me 220AH capacity without any problems at all. Not sure of the output of the alternators on these cars but I would guess at least 1.5-2.0 kW. |
Very interested to know how and where you fit this in an L405? Can you please share the details?
