Home > Technical (L322) > Heated Front Screen
Andy
Heated Front Screen
had cause to use it today for the first time. Compared to an old Fiesta we used to have years ago that had it, it seems to take a while to clear and I've noticed that it doesn't clear all the way to the A Pillars either- it's about 6" short either side.
My wife swears the fiesta was the same, but did admit it cleared quicker.
Can anyone confirm if it's correct? Seems strange that it's exactly the same both sides, suggesting the elements are intact.
Post #3377 5th Mar 2009 8:18am
Mine does the same thing on the passenger side , its about 6"short from the A pillar other side is fine , never really bothered about it tho .
Post #3380 5th Mar 2009 9:11am
if you look closely into the screen you can see the wires that heat the screen, you can see there is a band on either side that is not covered by the wires, ergo, unheated. Discovery 4 HSE
Post #3387 5th Mar 2009 11:36am
but it is only on my passenger side , drivers side it is wired right up to the A pillar
Post #3390 5th Mar 2009 11:44am
Andy
Mine is wired right up to both A pillars but as I said, it stops 6'' short when switched on.
Post #3402 5th Mar 2009 3:32pm
