Home > Maintenance & Mods (L322) > De Tango a 2002
paul_h_8
2002 Range Rover Vogue Td6 Bonatti Grey
De Tango a 2002
Been thinking of getting rid of the orange bits in my lights.
Can this be done with headlights?
Side indactors should be easy.
Rear lights was thinking supercharged lights would these be a straight swap?
Any help or advice, pictures etc
Thanks
http://gallery.me.com/paul_harland/100010
Range Rover Vogue TD6 2002 "52"
Bonatti Grey
Post #50912 19th Feb 2011 7:06pm
Royle
I'm not sure about the headlights but as you say the indicators should be straight forward. The rear lights are a plug in and go up to 2010 IIRC. The 2010 lights need rewiring otherwise they don't work properly. I hope that's correct anyway. Thumbs Up
Post #50913 19th Feb 2011 7:15pm
GregP
United Kingdom 2002 Range Rover HSE Td6 Adriatic Blue
Yep, I think Royle is spot on here. I was looking into it earlier. I like the look of the rear lights with the clear indicator rather than orange. Then add some clear side repeaters. Not sure about the headlight. FFRR TD6 HSE
Adriatic Blue with Parchment leather.
Post #50958 19th Feb 2011 11:22pm
GregP
Check out ajays post about half way down.
http://www.fullfatrr.com/forum/topic4826.html
Its a good pic to compare the different options. FFRR TD6 HSE
Post #50960 19th Feb 2011 11:25pm
Andy
I was wondering in the early days, whether a clear side light lens could be fitted in place of the orange. They appear to be the same size. I contemplated buying another couple of units, then dismantling them. Never bothered in the end..
If you do it, let us know how you get on. 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #52152 28th Feb 2011 4:15pm
mrjamescollins
United Kingdom 2005 Range Rover Vogue Td6 Java Black
I'd be interested in taking your rear lights if you go ahead with the clear update.
Post #52274 1st Mar 2011 8:36am
