Home > Technical (L322) > Key battery problem.
Baltic Blue
Help please,
I am away from home at my son’s wedding and just got key low battery warning.
I had a new battery available so decided to change it, but ever since I am getting key not recognising message.
I luckily have the spare key with me, but , it has not been used for quite a while and , you can guess... key low battery warning.
I can’t risk changing the battery in the second key at least until I get home.
How long do they last with low battery warning .? Just keeping fingers crossed.
Any ideas for me to try and fix No1 key?
I will get a new battery as soon as possible but the one I fitted was new and still sealed.
Post #495010 8th Nov 2018 3:01pm
bad news Mike...
i can only suggest that you leave the FF for half hour or so and see if that message still comes up..
Post #495012 8th Nov 2018 3:09pm
dolph34
Hi Mike, if you have your IID tool with you , you could try re coding the key, it only takes 2 mins. Congrats to your son Thumbs Up 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #495015 8th Nov 2018 3:24pm
Woofster
Canada
My apologies if this is slightly off-topic but when you change the battery in one of the remote key fobs, do you have to re-sync the keys so that you maintain the driver personalization settings that are designated to that key number?
Post #495019 8th Nov 2018 3:30pm
Full Fattie
United Kingdom 2007 Range Rover Vogue SE 4.2 SC V8 Zambezi Silver
I don’t know what key you have but I’ve read about people changing keys and dropping the little black but that links to the car, sounds like it looks like a small piece of plastic but it’s inportant. Someone with more knowledge than me will explain more I’m sure.
Post #495020 8th Nov 2018 3:39pm
Baltic Blue
Thanks all.
Stan, I have just retried key No 1, but it appears dead.
I will have to hope No2 lasts , but I am away until Saturday PM.
I presume they don’t need re coding after a battery change, but if it still doesn’t work after a second new battery, it will be the next step.
Post #495021 8th Nov 2018 3:40pm
i did mine recently so no re-code after battery change Mike, good luck chap Wink
Post #495022 8th Nov 2018 3:43pm
JST
England 2012 Range Rover Westminster 4.4 V8 Stornoway Grey
I changed myspare fob battery last week and no recoding needed! Cheers
James
Post #495032 8th Nov 2018 4:52pm
Jomo
United Kingdom 2011 Range Rover Autobiography 5.0 SC V8 Nara Bronze
There are a few posts on here that suggest that the remotes can be sensitive to the brand of battery. Might be worth trying to get hold of a different brand. Duracell seem to get mostly positive comments and worked for me. 2011 5.0 S/C
Post #495052 8th Nov 2018 10:55pm
nino_nino
+1 with Jomo, and check that you have put battery right side up (it has happened)
pic. of mine - I've just removed and put back battery and no problems.
 2012 TDV8 Black Edition
2000 Disco. TD5
1975 series III
Post #495060 9th Nov 2018 9:25am
Baltic Blue
Friday morning update.
Key No 1.
I have removed the new battery and re-fitted the original battery.
It works again, but obviously still giving Low battery. message.
New battery is obviously faulty.
Both are Maxcell.
I will buy 2 new Duracell on way home or ASAP.
Thanks for help.
Post #495074 9th Nov 2018 11:32am
good news mike...all the best to your son and his bride.....
Post #495078 9th Nov 2018 11:44am
Baltic Blue
Thanks Stan.
All went well.
B.B. is more like a transit van at the moment , back seats folded flat and packed solid to roof.
Cheers
Post #495140 10th Nov 2018 8:30am
Baltic Blue
I have just opened a brand new strip of 5 Maxwells CR2032 batteries, dated Expiry date 12-2024 and out of 4 of them in Fob No.2 not one works. That fob had a Panasonic. battery in which I have refitted, and it works perfectly, but is giving low battery warning.
I have just ordered a pack of 6 Panasonic CR 2032 off eBay and will retest when they arrive
Post #495159 10th Nov 2018 1:34pm
Baltic Blue
Updated Monday 14th Jan.
I did in fact buy new Duracell type batteries, and as soon as I fitted them to both fobs, all was well .
Both keys worked perfectly with no re- coding.
Post #501480 14th Jan 2019 9:08am
