Home > In Car Electronics (L322) > Analogue clock 2003 l322 vogue
jefus957
England 2003 Range Rover Vogue SE Td6 Zambezi Silver
Hi can anyone help how do you remove the clock from dash
Post #494676 5th Nov 2018 10:00am
fisha
IIRC: The side panels of the centre dash ( the bits with the vertical pieces of wood which you knees rest against ) come off exposing the mounting screws that hold the centre units in place. V8 or else ...
Post #494681 5th Nov 2018 10:44am
jefus957
Will have a go at removing them to get at the clock thanks Thumbs Up
Post #494685 5th Nov 2018 11:24am
fisha
I think the side bits are held on with clips and just pull off. But check anyway that there arent any screws down in the footwell area nearer the footrest V8 or else ...
Post #494689 5th Nov 2018 12:02pm
Paul thornton
There is one screw on each side from memory then clips at the front.
Post #494699 5th Nov 2018 1:44pm
