Home > Technical (L405) > Timed Climate stopped working
WeeJ
My 2017 Vogue has timed climate, which I used to be able to access from the mobile app. Now there's nothing in car and the app is set to off. When I turn the app on it asks when I want this to start. The earliest option is the next day but even when you select and save this option it doesn't reappear the next day. I've even stayed up until midnight to try and catch it as it changes over but that didn't work.
What's wrong or what am I doing wrong. Manual and dealer of no help at all.
Post #494382 2nd Nov 2018 7:54am
ADI
England 2016 Range Rover Vogue SDV8 Fuji White
Have a read of this thread.
http://www.fullfatrr.com/forum/topic44512.html
On the last couple of pages if you have an Android phone rolling back the app version solved missing journeys.
Maybe sort out the timed climate as well ??
Andrew BMW X3 30e XDrive M Sport
GoneBMW 330e
Gone MY2016 RR Vogue Fuji White SDV8 with a few extras...
Gone MY2016 Discovery Sport HSE
Post #494401 2nd Nov 2018 11:24am
WeeJ
Thanks ADI. Can't roll back iPhone IOs but tried deleting the app and re-installing. Had to sign in again but you need to do that regulalry anyway.
Long story shortened, it didn;t make any difference.
Is there anyone at JLR that can be contacted on this? Local dealer totally unhelpful (Peter Vardy Aberdeen) 1998 Freelander XEdi
2003 Freelander HSE
2006 Freelander V6
2006 Disco 3 TDV6
2012 Range Rover Vogue L322
2014 Range Rover Vogue 2014 L405
2017 Range Rover Vogue 2017 L405
2021 Mercedes GLE400d AMG Premium Line
2024 Range Rover Westminster 2021 L405
Post #494421 2nd Nov 2018 1:43pm
Charles89
United Kingdom 2014 Range Rover SVAutobiography SDV8 Scotia Grey
For anyone else suffering this issue, I recommend you use the webasto mobile app, far more features and verybuser friendly. I can't speak for RR. But my Audi had the same issue, they updated it and broke it. My solution was to use the app for Audi stuff (pre loading navigation routes and so on) and I then used the webasto app for everything heating related, I am not sure how well integrated the RR app is with the cars AC Hvac system but on the Audi I could even use the Webasto app to set a pre defined temperature for the cabin. Rather than just Hot I could specify 24c etc.
Worth a look at. And an easy ish upgrade to the existing webasto using. Just do away with the T91 receiver and install the SIM card receiver instead, and then you do not have to be in range of the car to press the button, you can use the app instead
Post #495886 18th Nov 2018 1:24pm
