Home > Technical (L322) > Rear suspension sensor wiring
Geo2toy
United Kingdom 2011 Range Rover Vogue SE TDV8 Java Black
Hi Guys
So I have a fault that I thought was the sensor but I've changed it and its still got the fault on the rear right sensor!!
So plugged in the code reader and 0 voltage at the sensor .
so checked the plug and wiring as far as I could until it enters the body.
My question is how do I get to the wiring on this in a 2010 MY 3.6 TDV8 ?
as its not in the boot and looks to be entering in front of the fuel tank but I cant get at it from underneath with the car jacked up so It looks like rear seats and carpet out Job.
Any help much appreciated
Geo[/b]
Post #493929 28th Oct 2018 7:32pm
The wires will be running back to the ECU which IIRC is tucked away behind the glove box somewhere. Best to check the resistance of these wires. The cable run will be buried under the carpets all the way back. .
Post #493938 28th Oct 2018 8:08pm
Geo2toy
Thanks Joe that's my concern full strip out of the interior basically Big Cry
Post #493943 28th Oct 2018 8:33pm
