Home > Technical (L322) > Adaptive dynamics fault STILL!!!!
Geo2toy
United Kingdom 2011 Range Rover Vogue SE TDV8 Java Black
Hi All
So cant get to the bottom of this problem! 2010my 3,6T DV8 Adaptive dynamic fault
Thought it was the usual front wiring issue at first but that's been done already and all checked out ok.
Now I can read the codes it says rear right height sensor so Ive replaced that and its still on wont clear and still saying rear right level sensor Big Cry
all the damper voltages read the same or there abouts. modules show no DTC faults.
terrain response also not working but no faults found.
Anyone have any ideas would be much appreciated. Thumbs Up
Post #493770 27th Oct 2018 4:51pm
GGDR
I had a RH rear sensor error and the cause was cable chaffing near the connector. Easily fixed.
You might have to start checking along the cable for chaffing damage starting at the sensor and working back.
There was also a post somewhere here - a guy had cable damage inside the boot / near the fuel tank where the cables came through the body.
. Cheers, Greg
Post #493771 27th Oct 2018 5:11pm
Geo2toy
Thumbs Up That's what Im thinking as its probably the same as the front wiring on the strut tops that is brittle.
Oh the joys Big Cry
Post #493775 27th Oct 2018 5:26pm
