Home > Wheels & Tyres > WHEEL OFFSET
MadL322
United Kingdom 2002 Range Rover HSE 4.4 V8 Cairns Blue
WHEEL OFFSET
Have an L322 4.4 2002 and looking to fit some new wheels. will this configuration work straight off the shelf or will I need mechanical intervention??
Offset: 53
Rim Width: 9.5
Stud Diameter:120
Rim Diameter: 20
Number of Studs: 5[/b]
Post #493519 24th Oct 2018 11:03pm
p38arover
Australia
Hopefully, that's pitch circle diameter, not stud diameter! Whistle Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #493523 25th Oct 2018 6:40am
DBB
United States
Those are the same specs as the L320 sport wheels and will work fine. If they are OEM Land Rover wheels, you will need the 2006+ lug nuts. Some tire sizes to consider are 275/50R20, 285/50R20 and 295/45R20
Post #493728 27th Oct 2018 5:01am
