Home > Maintenance & Mods (L322) > Fixed My Adaptive Dynamics issue, Need Connector help
Eric Cartman
Ireland 2010 Range Rover Autobiography TDV8 Santorini Black
Repaired a damaged connection that had been previously repaired on one of my variable damping shocks.
No more intermittent 'adaptive dynamics fault' and the rough handling that comes with it.
Also went to put in these illuminated cills I got
In true land rover / bmw fashion they don't include the power connectors for them in the loom, does anyone have any idea what these connectors are used for (somebody suggested side repeaters connector is the same ) , probably on a bmw/LR of the 2005-2010 era is most likely so I can go get some in a scrap yard, need the plug part that goes in to this) , would also accept somewhere I can get them online.
 Current Vehicles :
L322 2010MY TDV8 Autobiography
BMW E38 735i
BMW E63 645ci
Post #493142 21st Oct 2018 6:00pm
i'd change the plug/socket connectors..there are loads of cheap jobbys on ebay ...
Post #493150 21st Oct 2018 6:42pm
Baltic Blue
How did you connect the new wires to the top of the needle thin pins in the plug?
I tried to do the same, but the wire I bought was too thick.
Did you use very fine wire?
Post #493154 21st Oct 2018 7:04pm
Eric Cartman
luckily I didn't need to go that far, only repaired a junction some way down, the cap was just off so I could check them, if it failed up there id probably order one of the official repair kits. Current Vehicles :
BMW E38 735i
BMW E63 645ci
Post #493171 21st Oct 2018 8:51pm
m@ttsFF
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Buckingham Blue
Looks like TE AMP Superseal to me ... get them from RS
You’ll need a crimp tool
https://uk.rs-online.com/web/p/pcb-connector-housings/3141255/ 4.2 SC - sold , now bought back
4.4 AdBlu Tractor - Stolen
Post #493204 22nd Oct 2018 7:34am
