![]() | Home > Technical (L322) > Central locking problem |
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3222 ![]() ![]() ![]() |
BCU (body control unit) situated under the passenger seat. Easy to remove and replace yourself (1 hr). Bet u have slightly heavier power steering as well? |
gilesharrison Member Since: 04 Aug 2018 Location: Cumbria Posts: 163 ![]() ![]() ![]() |
Steering feels fine.
GavinBell Member Since: 10 Sep 2017 Location: Phnom Penh Posts: 88 ![]() ![]() ![]() |
interested in the answer to this as well - assume it is ok for mot if i make sure it is unlocked before they test it. Series 2a LWB Hardtop - ex British Aerospace that was then used in an armed robbery! not by me!
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35652 ![]() ![]() |
the latch sounds like its ok...i'd check connections and power going to the actuator..if there is power then i could be the actuator.. |
Is the latch and actuator not just a single unit? I was looking at used ones on ebay (around £30) and they appear to be a single part. |
yes it is a single unit, i meant the latch part of the unit is ok.. |
