Home > Maintenance & Mods (L322) > 2010-2012 programming a used CJB
Donnie
Germany 2011 Range Rover HSE 5.0 V8 Alaska White
Hey,
is it possible to reprogram a used CJB?
The car works, but the VIN number from the CJB is incorrect.
Regards
Post #491828 11th Oct 2018 5:37am
whats a CJB????
Post #491890 11th Oct 2018 4:42pm
Combustulated Jangerous Banana ?? Thumbs Up .
Post #491891 11th Oct 2018 4:45pm
AJGalaxy2012
Central Junction Box ? BMW i3 Electric Car
2006 VW Touareg 3.0 TDi V6
Post #491894 11th Oct 2018 6:00pm
Bushy30
United Kingdom 2011 Range Rover Vogue SE TDV8 Galway Green
Indeed, central junction box, or BCM apparently! And possibly RRS rather than FFRR Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
2004 FFRR Vogue 4.4 V8 with LPG
1997 P38 4.0 SE with LPG
1997 P38 4.6 Vogue with LPG
Post #491896 11th Oct 2018 6:07pm
AJGalaxy2012
BCM = Body Control Module?
(Different terminology from VW Touareg!) BMW i3 Electric Car
Post #491899 11th Oct 2018 6:14pm
Bushy30
Yes found folk talking about programming the CJB with the VIN, later referred to as BCM, Body control module (so makes sense) but it was all for Sports not FF Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
Post #491900 11th Oct 2018 6:31pm
Donnie
Central Junction Box it´s like the Body Control Modul from the BMW based cars
Post #491901 11th Oct 2018 6:40pm
comports
Hi Joe,
From memory - i think it related to my 54 Plate - it is possible but you will probably end up with a mileage conflict dot on the dash that cannot be removed due to the second hand BCM (I think it relates to any SH control modules to stop mileage tampering).
I was advised that only new BCM (or the similar Light Control Module or LCM that also did the same) would be needed to avoid that.
They should be fine to reprogram as long as you don't mind the dot and can explain when you sell the car the reason why its there. Ash
2016 SDV8 AB
Post #492189 14th Oct 2018 8:00am
