Home > Maintenance & Mods (L322) > Rear Bumper
barrieeld
Rear Bumper
Hi all, I am wondering I've noticed my rear bumper has a little gap, the car hasn't had a bump it seems maybe the clips holding the bumper are broken...I THINK? Is this an easy fix/repair?
 Range Rover SC 35th Anniversary 2006
Post #491733 10th Oct 2018 4:26pm
DMRR
The only L322 I owned (and two were from new!!!!) that didn't do this was my 5 litre SC (and it did after they replaced a parking sensor). It's basically thin plastic tabs which eventually wear with movement and - well you can see the end result! Land Rover Addict
XXXXXXXXXXXXXXXXXXXXXXX
Previous
XXXXXXXXXXXXXXXX
2009 5.0V8SC Autobiography
2006 4.2V8SC Autobiography
2004 4.4V8 Vogue
Post #491734 10th Oct 2018 4:29pm
JCW
Its tricky to remove the rear bumper without at least some of the retaining slots in the bumper breaking and/or the tabs in the concealed plastic trim they slot into breaking, although once the bumper is removed, this can be replaced by drilling the aluminium rivets out and re-rivetting a new part in.
Best advice from my experience is to gently warm the bumper in this area each side before carefully pulling the bumper outwards, not a good idea to start tugging on it when it's too cold.
Post #491736 10th Oct 2018 4:57pm
