Home > Technical (L405) > ABS, Stability and HDC Lights
Gibby
2013 Range Rover SE 4.4 V8 Causeway Grey
Morning all,
Had that lovely feeling when the dash lights up this morning. ABS, Stability and HDC I believe. Pulled over, turned it off and on again and it had sorted itself out. Something I should worry about or just a Tuesday gremlin?
Gibby
Post #490643 2nd Oct 2018 9:39am
Dolphinboy
Normally that indicates low battery. Check your connection on the battery. Even a little slack can cause it to move and not deliver enough juice.
Post #490668 2nd Oct 2018 1:42pm
