Home > In Car Electronics (L322) > Help
jk3528
United Kingdom 2003 Range Rover Autobiography 4.4 V8 Zambezi Silver
Help
Any one got a clue as to what this is
Post #490554 1st Oct 2018 3:24pm
Bushy30
United Kingdom 2011 Range Rover Vogue SE TDV8 Galway Green
Something to do with video or sound -- a model number from the back might help
This might help you search: -
http://www.autoleads-germany.de/veba.pdf Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
2004 FFRR Vogue 4.4 V8 with LPG
1997 P38 4.0 SE with LPG
1997 P38 4.6 Vogue with LPG
Post #490555 1st Oct 2018 3:29pm
after market reversing sensors???
Post #490556 1st Oct 2018 3:39pm
kds2
England 2008 Range Rover Vogue TDV8 Stornoway Grey
Mine has after market dvd player and screens by veba so maybe some thing to do with those if fitted ?
Post #490627 2nd Oct 2018 12:15am
Not oem......
Lots of insulation tape.
Quality install. Thumbs Up There is nothing that can't be fixed with a hammer😜😜
Post #490728 2nd Oct 2018 7:12pm
RRV78
England 2003 Range Rover Vogue 4.4 V8 Java Black
I found something similar in mine and was for aftermarket infrared headphones for my rear seat entertainment. Current: 16 my2016 Range Rover l405 4.4 sdv8 Aruba gold & 11 MY2011 RANGE ROVER L322 4.4 TDV8 ZERMATT SILVER
Previous
59 MY2010 Range Rover Vogue L322 3.6 TDV8 Zermatt Silver
53 Range Rover Vogue L322 4.4 V8 Java Black
98 P38 Range Rover 2.5 DSE Champagne Gold
Post #490746 2nd Oct 2018 8:46pm
jk3528
I think that's what it was 1 lead said audio the other was a power lead
as I don't have the headphones its gone
it also looks like a PlayStation was connected at some stage
only thing is I'm getting nothing on the radio screen
Post #491059 5th Oct 2018 10:06am
What are you getting ? Any sound ? Any video ? Blank screen ? Functionality ?
You may need to have a good sort out of the rear left cubby to see what is what.
My strip down from a few years ago may help. I didn't have a VEBA unit, but from the sound if it a similar set up with after market rear screens, infrared headphones, and a playstation ONE.
http://www.fullfatrr.com/forum/topic8786.html .
Post #491071 5th Oct 2018 11:25am
jk3528
blank
hi joe the screen appears to have the back light on but nothing else there must be power to it as the front opens so you can get at the cassette
but the radio light don't come on no sound or anything
Post #491098 5th Oct 2018 3:08pm
Well you have made a start by looking in the rear left cubby Thumbs Up
More work to do, as you will need to check all the connector blocks to all the units, especially to the BM54 (radio), DVD unit and video module. You will need to remove the black plastic cover to the boot (two plastic 10mm nuts and the luggage securing hook - allen key) along with the side carpet trim, in order to have decent access to everything.
It is worth removing the covers for these units as well, even though they may look dry on the outside, they may have suffered water ingress in the past and this is only now causing problems.
See here: http://www.fullfatrr.com/forum/post482337.html#482337
(my DVD player battery drain, and probably intermittent ICE shutdowns as well) .
Post #491099 5th Oct 2018 3:20pm
