Home > Maintenance & Mods (L405) > Front Fog Lamps
Hairy Dan
United Kingdom 2014 Range Rover Vogue SE SDV8 Luxor
Front Fog Lamps
Has anybody fitted front fog lamps to a L405 VSE? Is the wiring present? Do I just need 2 fog lamps and a new Indicator Headlight Switch Stalk? Thumbs Up Cheers Ian
Kielder 4x4 Safari
Post #490226 28th Sep 2018 5:52pm
362bkr
I believe it is financially prohibitive . Big Cry
Post #490229 28th Sep 2018 6:04pm
Hairy Dan
Do you mean it needs more than the lamps and a switch 362bkr? Cheers Ian
Kielder 4x4 Safari
Post #490230 28th Sep 2018 6:06pm
362bkr
From memory yes. When I enquired in 2014 it was a lot of money and a lot of aggro which was daft as it wasn’t an expensive option when new . I could not believe at the time that you could buy a car at this value without them fitted as standard .
Post #490231 28th Sep 2018 6:14pm
362bkr
Only standard fitting on the AB.
Post #490232 28th Sep 2018 6:15pm
Hairy Dan
Thanks for that, I was surprised when they weren't fitted as standard Thumbs Up Cheers Ian
Kielder 4x4 Safari
Post #490233 28th Sep 2018 6:30pm
Nig
United Kingdom 2014 Range Rover Vogue TDV6 Indus Silver
If I recall correctly fog lights were a £150 extra on my L405, was plug and play on my P38 as an after fitment, someone’s grabbing the cash 💴 L405, MY14 3.0 V6
Post #490354 29th Sep 2018 7:12pm
I think you may need a bumper loom too I'm afraid... Rolling Eyes
Post #490362 29th Sep 2018 7:56pm
Hairy Dan
Cheers guys, I did wonder if it was just a case of plugging them in like a lot of things on Discovery's but it looks like it may be a bit more involved Sad Cheers Ian
Kielder 4x4 Safari
Post #490375 29th Sep 2018 8:47pm
Do you actually need them ?
Other than to test them, I’ve never used mine - the headlamps are perfectly good enough IMHO
If it’s purely aesthetic then just fit the lamps and forget about the wiring Whistle
Post #490379 29th Sep 2018 9:01pm
Hairy Dan
I don't actually know whether I 'need' them as such as I haven't had the car for long, it was only earlier on this week that I drove it in the dark for the first time, Laughing I was amazed they were an extra at build albeit a cheap extra and I thought that if it was just a case of fitting the lamps and switch with maybe all the looms being the same I would do it for a reasonably small cost.
This is my first full fat and coming from Discovery's they tend to have one harness etc fits all and it's just a case of fitting extras and maybe enabling them with the IID Tool and Robert's your mother's brother it works. I have already switched timed climate on my FFRR with the IID tool so some things are possible I just wish I could have it operate from a remote like you can on the Disco's Crying or Very sad Cheers Ian
Kielder 4x4 Safari
Post #490381 29th Sep 2018 9:29pm
Vogue
Its bonkers LR don’t fit them as standard - they were only £116.67 ex vat to fit when I bought mine - plus the an extra £25 ex vat for the extra windscreen washer bottle. They then charge £3k extra for Turbines, the pathetic extra time involved in admin fitting the fogs and washer bottle and the tiny sum generated they would be better off fitting as std. 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17
Post #490390 30th Sep 2018 6:34am
Chalky
They were £3750 on my new VSE , but............
I did get British Racing Green and surround cameras as well!! Seems daft, I asked the dealer why, in order to get BRG, you automatically get Fogs and Surround cameras and he didn't know why. Whistle
Post #490405 30th Sep 2018 10:36am
JLR are clearly worried about your eyesight if you order Green Whistle
Post #490462 30th Sep 2018 7:53pm
kiwirich
Australia 2017 Range Rover Vogue TDV6 Fuji White
Good Morning gents,
Does anybody have photos of Fog lights mounted in a bumper , a view from the inside to show the mounts etc ?
I understand that the wiring is still required but trying to understand the mounting hardware , brackets etc required .
Any help appreciated
Kiwirich
Post #511971 13th Apr 2019 7:42pm
