Home > In Car Electronics (L322) > Features that never made it to the 2010-12 L322 LCD Cluster |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2538 |
The displayed speed is cruise control set speed which is displayed on mine. At least mine has a fuel gauge! |
25th Sep 2018 11:11pm |
Eric Cartman Member Since: 05 Nov 2014 Location: Dublin Posts: 108 |
True, noticed that ha. Just seems like many obvious features are absent and were for the whole model. Current Vehicles :
25th Sep 2018 11:29pm |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3550 |
It's at it's best when you change to off-road mode e.g. snow or sand and/or select low range. The speedo dial moves over to the right making room for more info liike the diff lock status.
26th Sep 2018 1:29am |
Tinman Member Since: 22 Mar 2017 Location: kent Posts: 1194 |
The IID tool will do so much If travelling to Europe just change from MPH to KPH makes life so much easier? |
26th Sep 2018 8:07am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35436 |
you can change the main speedo dial to kph via the dash menu....
26th Sep 2018 8:11am |
IanV8 Member Since: 14 Jan 2010 Location: Dunfermline Posts: 502 |
Not on mine, if you change to kph it just puts the digital readout up in kph, it does change the sat nav to kms which is a pain.
26th Sep 2018 8:25am |
you need an iidtool to change the digital to mph Ian... |
26th Sep 2018 8:29am |
kooky_guy Member Since: 25 Nov 2011 Location: Sandhurst, Berkshire Posts: 386 |
Makes me wonder if the code for those functions is still in there - it seems a bit strange that they would just remove it all. 2010 4.4 TDV8 Vogue SE |
26th Sep 2018 8:41am |
