Home > Maintenance & Mods (L322) > Instrument Cluster
Instrument Cluster
Morning
Well another day, another glitch Big Cry . Just come out of work and as well as a few MIA pixels the milage section of the cluster appears to have no back light. Very random Shocked . How is the cluster illuminated and if it's bulbs are the changeable by me or does it need opening up?
Thanks
Rob
Post #51300 22nd Feb 2011 7:14am
It's bulbs that are accessed by removing the cluster. To remove it you need to remove the two side vents and dash top
Post #51305 22nd Feb 2011 7:57am
That's good. So it's a simple DIY fix?
Post #51335 22nd Feb 2011 12:02pm
stevegt
United Kingdom 2006 Range Rover Autobiography 4.4 V8 Cairns Blue
Well sort of...
Depending whether you have 06MY or later there is a fixed wire on these models that goes to the front sounder in the overhead console. This means that you can't fully remove the cluster. Also the cluster is surrounded by a black plastic 'cage'. Now this can be removed my carefully prising open the plastic clips with a small screw driver and removing the retaining screws. After that you can access the bulb holders.
All in all the job should take a couple of hours to remove the dash top, instrument cluster and refit. Off the top of my head you will need a t30, t25, precision screwdrivers (to remove side vents) and a cross head screw driver. Oh and maybe just a pinch of patience to remove the side air vents... 06MY 4.4 V8 Autobiography Cairns Blue with Navy & Parchment Interior
Post #51532 23rd Feb 2011 11:05am
Andy
Mine has done exactly the same thing.. 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #51621 23rd Feb 2011 6:59pm
andrewcooke1720
Ireland 2012 Range Rover Westminster 4.4 V8 Barolo Black
check out the powerful.uk web site on replacing the side vents. it shows a video of how to remove the vents which is the trickiest thing. i then sent my cluster to bmwpixelfix. happy days.
Post #51955 26th Feb 2011 1:31pm
