Home > Maintenance & Mods (L405) > L405 Headlight Bulb Replacement
Diablo
All, can someone please advise on the process for changing the headlight bulb on a L405 TDV8? I do not have the time to take it to a dealer, so was hoping I can do it myself.
Many thanks.
N
Post #489210 18th Sep 2018 12:13pm
you mean the xenon bulb???
this is from the sport workshop manual and i should imagine its the same for yours,
Post #489212 18th Sep 2018 12:42pm
Diablo
Hi,
Thanks for that. The trouble with the engine bay on mine is that there seems to be no easy way of removing that cover as there are so many engine components pushed up against it. I am hoping it is not a bumper off/headlight out job.
Many thanks.
Post #489227 18th Sep 2018 2:59pm
This may seem a lot of work but its the easiest way! Simply remove the air box (top and bottom) on which ever side you need to replace and VOILA Bow down You can gain access Thumbs Up
Post #489242 18th Sep 2018 5:05pm
charlie croker mk2
Yes the air filter box has to come out , its dead easy after undoing the pipework and then just lift up and at the same time to the centre of the car . Same on the V6 . I suppose its worth mentioning to take the headlight switch out of "Auto" to avoid the lights switching on !
Post #489253 18th Sep 2018 6:43pm
Diablo
Gents, really appreciate the input! Thumbs Up
Post #489360 19th Sep 2018 9:41pm
Charles89
United Kingdom 2014 Range Rover SVAutobiography SDV8 Scotia Grey
Can anyone recommend a brighter bulb? And also what bulbs are they?DS2s?
Mine seem awful and I want to go as bright as possible as I am struggling to see anything on dipped beam, these lights are awful.
2014 L405 by the way with advance front lighting (aptly named Rolling Eyes )
Post #536223 3rd Dec 2019 7:51am
d3s type,
read this,
https://www.fullfatrr.com/forum/topic53573.html ... - .- -.
Post #536227 3rd Dec 2019 8:20am
Charles89
Done and its a 100% improvement Thumbs Up thanks gents
Post #537133 12th Dec 2019 6:52am
