Home > Technical (L322) > Fuel Burning Heater
AJGalaxy2012
Fuel Burning Heater
I have heard it run when Ive done a short journey and the engine hasnt warmed up. I have tried running it manually without the engine running, I press the manual heat soft key. I can hear the flaps move in the ventilation system, I hear the fan start up on the burner and then after about a minute it shuts down. No errors, no warnings, no messages at all.
I do have the GAP tool is there anything I can look at to find out why it doesnt heat the car? any ideas what may be wrong?
Thanks - AJG BMW i3 Electric Car
2006 VW Touareg 3.0 TDi V6
Post #488114 6th Sep 2018 7:19am
IanV8
Scotland 2011 Range Rover Vogue SE TDV8 Santorini Black
The air temperature might be too warm, can’t remember what it has to be below.
Ian
Post #488122 6th Sep 2018 9:18am
Baltic Blue
AJG.,
The full PDF for the FBH is in Wiki.
Hope that helps
Post #488123 6th Sep 2018 9:50am
Henda
United Kingdom 2006 Range Rover Vogue TDV8 Zambezi Silver
+5 if it's the same as the disco Thumbs Up
Post #488139 6th Sep 2018 12:41pm
MikeO
Scotland 2009 Range Rover Vogue TDV8 Buckingham Blue
I think it's below 6 Celsius for the Disco. But the remote fob should trigger it for a full cycle irrespective of the air temperature AFAIK. I ran mine the other day and it ran for quite some time - on my D3 it would run until either a certain coolant temp was reached or a time threshold was exceeded. 2016 Skoda Octavia VRS Estate
<gone>2009 FF Vogue TDV8 Buckingham Blue</gone>
<gone>2015 BMW 520D SE (not my favourite car)</gone>
<gone>2009 D3 HSE Galway Green</gone>
Post #488209 6th Sep 2018 9:26pm
Nah, won’t run on the fob unless it’s cold enough either.
Listen at the rear of the car for a faint clicking/ticking, this is the FBH fuel pump to get an idea whether it should ignite. There is nothing that can't be fixed with a hammer😜😜
Post #488309 7th Sep 2018 5:17pm
AJGalaxy2012
I can hear the heater FBH fan running (Ive had webasto's on Ford Galaxy and VW Touareg), I dont hear it ignite i.e. the roar that is usually associated. Are they accessible with GAP tool to see whats going on?
Actually, just had another thought, could the noise Im hearing at the front be a water pump? BMW i3 Electric Car
Post #488314 7th Sep 2018 5:41pm
Rambles
Not the same as the disco
Even if temp greater than the threshold, the system will still vent
Post #488342 7th Sep 2018 9:28pm
MikeO
Yep, mine runs on the fob even when temp is well above 6 Celsius, more like 12. And that tallies with the FBH description in the wiki. 2016 Skoda Octavia VRS Estate
Post #488344 7th Sep 2018 9:31pm
MikeO
Ah, mine is a 3.6 though. Perhaps it's different on the 4.4? 2016 Skoda Octavia VRS Estate
Post #488346 7th Sep 2018 9:32pm
the 4.4 is a bit more fussy when it will run, true. IIRC on my 3.6, it would cycle through the fans etc but wouldn't kick the actual burner in if it was too warm on the fob. could be remembering incorrectly tho. Thumbs Up There is nothing that can't be fixed with a hammer😜😜
Post #488372 8th Sep 2018 8:02am
AJGalaxy2012
I guess I'll have to wait for it to get cold!
Post #488398 8th Sep 2018 12:24pm
MikeO
If you really want to test it, use a freeze spray or an ice cube on the temp sensor behind the grille. 2016 Skoda Octavia VRS Estate
Post #488410 8th Sep 2018 3:57pm
AJGalaxy2012
I suppose I could connect my decade box to it and dial in whatever temp I want. I may give it a try tomorrow, good idea, thanks ! BMW i3 Electric Car
Post #488413 8th Sep 2018 4:14pm
kooky_guy
United Kingdom 2010 Range Rover Vogue SE TDV8 Stornoway Grey
Re: Fuel Burning Heater
Thanks - AJG
Mine's doing exactly the same. I'm about to put a new battery in as the rest voltage is a bit low on mine. Hoping that will fix it. Mine did work on the timer the first few times I tried it last winter but then appeared to stop. 2010 4.4 TDV8 Vogue SE
Post #488549 10th Sep 2018 6:44am
